mag pushrod tunnnel clearance ? #1514905
10/10/13 11:53 AM
10/10/13 11:53 AM
RapidRobert Offline OP
LA block/mag heads. I ground the parting line that was about halfway down the tunnel & smoothed out the whole area (pushrod was touching the parting line on mockup). How much clearance do I need between pushrod/wall? thank you for your time.
Re: mag pushrod tunnnel clearance ? [Re: RapidRobert] #1514906
10/10/13 12:53 PM
10/10/13 12:53 PM
I think .030 to .060 should work well Don't forget that you may have some flex with the real springs and some heat in the motor so more is better, but rubbing in the middle(AKA guide plates, some may rub) may not be a bad thing as long as it does not make metal or create heat in either component
Re: mag pushrod tunnnel clearance ? [Re: RapidRobert] #1514907
10/10/13 02:37 PM
10/10/13 02:37 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
not sure on the clearance, but I`m curious what combo of parts you are using. I just put together an LA/mag. combo and didn't have any problems. I used an 85 roller block, mag. heads, edelbrock hardened pushrods, comp cams studs/guide plates and 1.6 chevy roller tip rockers. is it a hyd. flat tappet cam/block?
Re: mag pushrod tunnnel clearance ? [Re: 65rbdodge] #1514908
10/10/13 04:45 PM
10/10/13 04:45 PM
It's an early non roller LA block & the heads were some bare new ones I bought a decade ago & I need to find the receipt for them (might be EQ's which are very good). I Used OE MP mag rocker arms/studs/guide plates & adj MP pushrods. EDIT flat tappet cam
Re: mag pushrod tunnnel clearance ? [Re: RapidRobert] #1514909
10/10/13 04:50 PM
10/10/13 04:50 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I used Chevy 1.6 roller rockers on my mag heads and I had to do a bit of grinding on the parting lines and a bit more....... Easy work with a die grinder....... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: mag pushrod tunnnel clearance ? [Re: tpabayflyer] #1514910
10/10/13 04:53 PM
10/10/13 04:53 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I should also mention I was using a non-roller block so the pushrod length was longer and I think this made the problem worse...... Roller lifters and shorter pushrods would help........ TBF
Re: mag pushrod tunnnel clearance ? [Re: tpabayflyer] #1514911
10/10/13 05:00 PM
10/10/13 05:00 PM
Yes I was real fortunate to have had those MP adj LA pushrods on hand which were much longer
Re: mag pushrod tunnnel clearance ? [Re: RapidRobert] #1514912
10/10/13 07:38 PM
10/10/13 07:38 PM
Anytime you change the rocker arm ratio from a 1.5 to a 1.6 you move the pushrod closer to the center of the rocker arm
Re: mag pushrod tunnnel clearance ? [Re: Cab_Burge] #1514913
10/10/13 07:45 PM
10/10/13 07:45 PM
Which if mags were 1.5 I'd be in even worse shape. Cab I think I'll keep grinding till I get the .060" you recommended. The walls are thick so no problem there it's just that I dont like porting so the quicker I get enough clearance the better. Thanks guys!
Re: mag pushrod tunnnel clearance ? [Re: RapidRobert] #1514914
10/10/13 09:13 PM
10/10/13 09:13 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I was under the impression that the adj pushrods were for findling the proper length and then having the real deal made.. The few that I have seen dont look strong enought to use in a running engine..
I am truckless..
Re: mag pushrod tunnnel clearance ? [Re: 340SHORTY] #1514915
10/10/13 09:36 PM
10/10/13 09:36 PM
These are MP ones meant to be run. I'm assuming that a "checking" pushrod has more adjustment so you can find the correct length needed on any engine but I'm not sure as I ain't never had one in my possession & that extra length may make it unstable but I do not know that to be a fact. I tried to post a pic of the the MP ones I have but my camera setting was too high & this site wont accept it. In my case iirc even the MP fixed length ones for the conversion were too short
Re: mag pushrod tunnnel clearance ? [Re: RapidRobert] #1514916
10/10/13 11:07 PM
10/10/13 11:07 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i used the MP adjustable pushrods in a 3.9v6 i put together a while back. i put a lot of miles on it before i sold it. it had stiffer than stock springs on it too. you should be ok with them
Re: mag pushrod tunnnel clearance ? [Re: 65rbdodge] #1514917
10/11/13 12:15 AM
10/11/13 12:15 AM
That's good to hear as it's going into a circle burner & will be pushed hard
Re: mag pushrod tunnnel clearance ? [Re: RapidRobert] #1514918
10/11/13 12:47 AM
10/11/13 12:47 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
.010" is plenty and it's unlikely you need to grind anything.
Re: mag pushrod tunnnel clearance ? [Re: goldmember] #1514919
10/11/13 11:13 AM
10/11/13 11:13 AM
The parting line was substantial & was touching the pushrod so it had to go. With it gone & everything smoothed a bit I do have more than .010" right now
