Re: Help me pick a new converter.
[Re: midnite360]
#1514751
10/11/13 03:16 PM
10/11/13 03:16 PM
Posts: 1,106 Northeast
VincentVega
Northeast
for that RPM range and gearing you can probably use almost anything. FWIW late 70s big block cop cars were in that range (2600-2800) and they petered out at 4000 rpm. they ran ok with them. if you are adventurous you could try a stock converter and see where it winds up. making more power should push the stall speed up
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: VincentVega]
#1514752
10/11/13 09:47 PM
10/11/13 09:47 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
IIRC 360s had 727 trannys so a 360/727 torque converter wont work in a 904..
I am truckless..
