06 Dodge Ram Heavy Duty 2500? #1514372
10/09/13 07:43 AM
10/09/13 07:43 AM
USA
Lawn Monkey Offline OP
USA
I just bought an 06 Dodge Ram Heavy Duty 2500 , its called a "Heavy Duty" , question is are all the Ram 2500's "Heavy Duty" or are there different versions of the 2500 series?
Re: 06 Dodge Ram Heavy Duty 2500? [Re: Lawn Monkey] #1514373
10/09/13 01:28 PM
10/09/13 01:28 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine is a 2500 HD also. It has the heavier duty front 4500 lb rated front axle. Snow plow prep package with heavier duty front springs, higher amp alternator, trailer/tow package. Larger dia 3500 series brakes. And probably a few other things I am forgetting.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 06 Dodge Ram Heavy Duty 2500? [Re: 6PKRTSE] #1514374
10/10/13 09:26 AM
10/10/13 09:26 AM
USA
USA
Thanks for the info 6PKRTSE , going to check into thge details, I am new to Dodge trucks, so far my door sticker tells me I have a 5200lb front springs, that's good since it has a dealer installed snowplow.
My front axle is massive too no tags to tell me if its a Dana but it so big I doubt I can break it.
I have one gas tank, bummer on that but it is a large one, about 6 feet long .
How are these trucks on winter weather, I have 245/17's, kind of wide imop for snow wish they were one size narrower like Ford does .
How does one know what type rear differential it has, hoping for a Sure Grip or what ever they call it now a days.
Worm gear steering , I thought Mopar went new age and trucks had rack and pinion.
Lovin my neew Mopar truck so far plates tomorrow aand the maiden voyage...
Re: 06 Dodge Ram Heavy Duty 2500? [Re: Lawn Monkey] #1514375
10/10/13 12:22 PM
10/10/13 12:22 PM
Kansas
cascius Offline
cascius  Offline
Kansas
Should be an American Axle. They did away with the Dana's after 2002.
As far as I know Dodge did away with dual tanks after '93. In the 3rd gen trucks the long beds will have a larger tank than the short beds. I believe it's 26 gallon vs. 34 gallon, or somewhere along those lines.
245's are the smallest tire Dodge uses. My '03 was factory equipped with 265's and I run 285's on it.
Should be a code for it on the tag in the glove box. Should also tell you the gear ratio.
Only on 2wd trucks. I don't think it's possible to run rack and pinion on a solid axle. Be careful if you ever have to replace tie rod ends or drag links. We did this on my brother-in-law's truck and had to buy a complete kit that changed it over to the 2008+ style. They totally redesigned the front drag link, tie rods, and steering stabilizer.
Re: 06 Dodge Ram Heavy Duty 2500? [Re: cascius] #1514376
10/10/13 08:59 PM
10/10/13 08:59 PM
USA
USA
Thanks great info , my glove box tag is not there or is it behind the glove box?
Re: 06 Dodge Ram Heavy Duty 2500? [Re: Lawn Monkey] #1514377
10/11/13 10:09 AM
10/11/13 10:09 AM
Kansas
cascius Offline
cascius  Offline
Kansas
I'm pretty sure it's normally on the inside of the glove box. Haven't seen one behind it yet, but that doesn't mean it couldn't happen.
Re: 06 Dodge Ram Heavy Duty 2500? [Re: cascius] #1514378
10/12/13 10:55 AM
10/12/13 10:55 AM
USA
USA
Thanks cascius
Tag not found but I called my local Mopar dealer and with vin he found that I have 3.73 gears, limited slip, snow plow prep package and trailer tow package ,, point for my Mopar dealer I doubt the fellas at Ford could or would get that info from a vin number.
