Re: Crankcase Pressure
[Re: mopowers]
#1511857
10/03/13 12:57 PM
10/03/13 12:57 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
There should be a breather opposite the PCV - regardless of the side it's on. But - what you're hearing is not crankcase pressure as one might think (bad stuff). It's escaping pressure from a cylinder that was sealed when you shut it down. No big deal.
[Re: moper]
#1511858
10/03/13 01:17 PM
10/03/13 01:17 PM
Posts: 3,007 Sac, CA
mopowers
Sac, CA
The hissing stops as soon as I crack the filler cap. I definitely need a breather there.
So is the pressure just slipping passed the rings of whatever piston moves up on the compression stroke after the engine is shut down?
