Page 3 of 3 1 2 3
Re: 11 second 1970 cuda with good street manners? [Re: derekeh] #1508892
11/06/13 10:32 AM
11/06/13 10:32 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I like the small block in our E-body. Lots and lots of room to work on it, and kind of different from the big block/Hemi most expect to see when we pop the hood.
Might want to weigh that 'Cuda and see what you're dealing with. Our Challenger is only 3,340 pounds, and that's with an all metal body, full interior, small block and 727. It weighs almost exactly the same as my Duster. Kinda sucks really...you'd think with an A-body I'd have a huge weight advantage.
Re: 11 second 1970 cuda with good street manners? [Re: dustergirl340] #1508893
11/28/13 10:23 AM
11/28/13 10:23 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
What kind of power can a small block handle? I have a 1970 340 standard bore and a 1977 360 .040 over both ready to be used if either one of them can handle boost ok. If not I may buy a new block if I go the wedge route. Just not sure what they can handle.
Re: 11 second 1970 cuda with good street manners? [Re: dustergirl340] #1508894
11/28/13 09:22 PM
11/28/13 09:22 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
EASY Dustergirl!....The opposition AND some fellow
Big Block Mopar racers often foul about the 340 Duster having an unfair advantage!!
Oh well... Let them KEEP seeing your taillights!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 11 second 1970 cuda with good street manners? [Re: derekeh] #1508895
11/28/13 09:31 PM
11/28/13 09:31 PM
Desert Tracker
Desert Tracker
A simple, BUT EFFECTIVE stroker setup on a 340/360 motor (yeiding in the 420-426) cube range should be streetable
enough to drive every day BUT run the 11-11.5 bracket in a 3500+ weight package w/4.10's. Carb, compression and converter stall depending.
Page 3 of 3 1 2 3
