Re: Orange box ???
[Re: earlybee]
#150680
11/14/08 03:50 AM
11/14/08 03:50 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
said to have a lil hotter spark,,,, but they sure have a substantial failure rate
I am truckless..
Re: Orange box ???
[Re: 340SHORTY]
#150681
11/14/08 09:24 AM
11/14/08 09:24 AM
Re: Orange box ???
[Re: ZIPPY]
#150684
11/14/08 11:47 AM
11/14/08 11:47 AM
340dart4spd
Parts Problem
Parts Problem
Go chrome every time.
I recall reading the chrome box runs HOT!! on the street
Re: Orange box ???
[Re: 340dart4spd ]
#150685
11/14/08 12:04 PM
11/14/08 12:04 PM
no, thats the RACE box. ive run chrome plenty of years to know it works just fine
Re: Orange box ???
#150686
11/14/08 12:20 PM
11/14/08 12:20 PM
Posts: 1,359 Buzzard County, FL
IronWolf
Buzzard County, FL
Both the Orange and Chrome ECU's utilize the 793266 power switching transistors.
The difference between the two is in the support circuitry hidden beneath the potting material.
Yes, they get hot. That's why Ma Mopar installed ECU "standoffs" on some models. My old Mirada ECU was mounted directly on the fender apron, and I burned through one or two stock ECu's. The orange box on our old Monaco got hot enough to melt the potting material, and it dripped down the firewall.
After reading this post, and having just gone for a cruise in the 'cuda, I verified that , yes, the transistor gets a bit hot.
But that's why the CPU on your computer right now has a cooling fan - millions of transistors, switching current. Except those transistors on the CPU are tiny, and the ECU transistors are big 70's Godzillas.
Re: Orange box ???
[Re: IronWolf]
#150687
11/14/08 12:22 PM
11/14/08 12:22 PM
340dart4spd
Parts Problem
Parts Problem
Thanks just my point!!
Re: Orange box ???
[Re: IronWolf]
#150691
11/14/08 12:44 PM
11/14/08 12:44 PM
concept of a heatsink is to physically conduct the heat away from the component where the air can cool it.
Mounting it on standoffs allow air to circulate around it but without the airflow (ie in traffic) it wont cool as well.
ive seen melted potting material on heatsinks before but not always. I wonder why some do it and some dont. Some have that yellow gel potting that melts easier than that dark brown rubbery potting.
Re: Orange box ???
#150692
11/14/08 12:49 PM
11/14/08 12:49 PM
IronWolf
Buzzard County, FL
Right. And that's exactly why I burned ECU(s) on my old Mirada (fender apron mounted).
Re: Orange box ???
[Re: 340dart4spd ]
#150694
11/14/08 01:09 PM
11/14/08 01:09 PM
Posts: 17,801 S.E. Michigan
ZIPPY
S.E. Michigan
Not with a 1 ohm ballast resistor Don't use a 1/4 ohm ballast for long distance street!
Sacrifice a TINY bit of spark by staying away from 1/4 ohm ballast resistors, and in my rather lengthy experience (over 100,000 miles on the same chrome box, and the same blaster 2 coil) they hold up really well.
Use a 1/4 ohm ballast, and you'll have 1. a slightly hotter spark 2. more heat to deal with and 3. higher failure rates for the coil and ecu.
I do have one ancient orange box left from the '80s that still works great, but by and large the chrome box has a longer lifespan and is worth the extra couple bucks.
Re: Orange box ???
[Re: IronWolf]
#150695
11/14/08 01:12 PM
11/14/08 01:12 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Sorry, Not trying to steal the thread but I had to post upon reading this. Shortly after getting my Challenger running for the first time in many years I noticed a black goo that had dripped from the ECU and down onto the exhaust. Not sure when it did this as most of the time I've worked on it I have rather poor lighting while trying to start it. When I saw it in the daylight it was solid and hard. Question is, Do I need a new one? It seems to start ok but loads up badly until it warmed up. Carb has a fresh kit in it but it was in really bad shape and I'm not sure the kit fixed every thing; Idle screws had some corrosion on them and I'm not sure of the codition of the seats. Also, I'm sure I probably need new spark plugs, but could a bad ECU cause it not to idle until warm? I don't think the goo has dripped since the first time I noticed it but haven't run it that much; maybe a total of an hour over three or four different occasions. What makes it get so hot now? Age?
Re: Orange box ???
[Re: ZIPPY]
#150697
11/14/08 01:29 PM
11/14/08 01:29 PM
you are on to something here.
I have always run the 1 ohm ballast and I havent had the problems others have had. That 1/4 ohm will juice the coil more which has its - side run thru the ign box. so ya, the 1/4 ohm ballast should heat the box up more
Re: Orange box ???
#150698
11/14/08 01:45 PM
11/14/08 01:45 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
Correct me if I'm wrong, but the ballast only controls the coil, the box uses a full 12V. And as far as the orange box, the old ones were great, the past 10 years though, they were junk and wont last no time.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
Re: Orange box ???
[Re: 70dart360]
#150699
11/14/08 01:47 PM
11/14/08 01:47 PM
the negative side of the coil is triggered inside the box. That is what that transistor does. It is a switch. It closes and opens the negative side of the coil when the magnetic pick up in the distributor tells it to.
So ya, more voltage and current to the coil, the more power thru that transistor so it WILL get hotter. If the heat cant be disapated fast enough, it will blow or melt that potting material
Re: Orange box ???
#150700
11/14/08 02:56 PM
11/14/08 02:56 PM
For short runs any of the boxes will take full alternator voltage but will get over hot for crusing around. Stock boxes are limited to 5500 RPMs. The coil will also take short periods of full voltage. But will boil the oil if left on to long. When you put more voltage thru the coil it will produce a hotter spark. But none of them will put out more spark than is needed to jump the gap on the plug. Thats why we open up the gap when we have hotter ignition systems to make the coil fire more voltage. The better quality of box you use the better it will handle the extra voltage. Thats why FBO designed their Box and coil to take Higher voltage with out melting down. But they still need a resister to control the voltage on the street . I run their system on my race car a full voltage but then the car rairly runs longer than a few minutes. Also they use better Transister and circutry that improves the slew rate which is the time it takes the signal to travel thru the box and to the coil. That slew rate is high on the Mopar boxes thats why they retard the timing. All boxes do it some, but the better the circutry the lower the slew rate and the less retard. FBO also has timing kits that allow you to adjust the distributor mechanical advance with out welding the slots and can be installed or removed with out damaging the distributor the kit has 4 preset curves but can be filed to make multipul advances www.4secondsflat.com
Re: Orange box ???
[Re: IronWolf]
#150703
11/14/08 10:27 PM
11/14/08 10:27 PM
Astro turfing that is new to me. Sorry if my info isnt worthy of your superior intellect I was just offering some info. If my suggesting people that can help others is astro turfing then so be it. And that the following guy put a MSD on his sons car and it didnt make any differance supports my assumption about ignitions not putting out more than they need to to jump the gap.Makes MSD kind of worthless like people that critisize others to make them selves seem better.
Re: Orange box ???
[Re: RapidRobert]
#150708
11/15/08 12:06 PM
11/15/08 12:06 PM
Posts: 1,822 Colorado
denfireguy
Colorado
that settles it(for me). My next one is going in fromt of the radiator a little bit off to the side.
You will have to watch out for moisture penetration. They are mounted back there for two reasons, get them out of direct spray from rain and to have the fire wall sink some of the heat away from the transistor. Don't get alarmed if the transistor gets warm, it is supposed to. The output transistors in your AM radio get hotter and manage to stay alive. I used to carry a spare ignition module for fear the thing would die and leave me stranded. After 30 years, I can't remember where I put it. The original won't die. I think it is in the gap between the trunk extension and the fender, now that I think about it. I will have to look. Its in a sandwich bag. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: Orange box ???
#150715
11/16/08 01:45 PM
11/16/08 01:45 PM
Slew rate is important and can retard the timing if its bad enough.
That being said, Ive heard the hype of FBO but being the sleptic that I am (as well as my electrical engineering background), I'd need to see so me numbers that back it up. And by numbers, Im not talking about tests run by FBO to sell their products but actual independent test numbers. Also, I could easily figure out the slew rate and any reliability issues if I saw a schematic and a parts list of each box.
Seems like its a heavil;y gaurded secret.
I actually removed the circuit board from an ignition box several months ago. the circuit is pretty elementary. I'd love to compare it to the FBO box to see whats different (if anything)
Re: Orange box ???
#150716
11/16/08 05:56 PM
11/16/08 05:56 PM
Well you'll just have to Call them but I would imagine that he's as likely to give you his product specs as MSD Or Fast EFI or any other electronics company. As a electrical engineer I would assume you know what kind of things that would cause a increased slew rate. I'm no engineer I use the product and it works But thats the last any of you will hear from me about that product or possibly any others since All I ever seem to get from You no it alls is greif when I try to participate on the site. So go stroke your egos and give someone else the greif I'm going back out to the shop and work on real cars.
Re: Orange box ???
#150717
11/16/08 07:27 PM
11/16/08 07:27 PM
denfireguy
Colorado
I agree. Since slew rate is a function of the band width of the amplifier, even with using a discrete pass transistor I don't think it should be a serious issue even at 10,000 RPM. Electronics have come a long way since Chrysler designed the ignition circuit but amps with slew rates adequate to pass even 100,000 pulses per second were common in that era. But you are right, the outboard circuitry would be the limiting factor. I am a proponent of using capacitive discharge ignitions such as MSD. It will limit the current through the ignition box whether it is orange, chrome, black or aftermarket. I am not endorsing MSD, in fact I have never used one. I have ancient Delta Mark 10s that I built in the 70s and they still work well for me but they have not been made for 25 years. But I am not racing, I just want a reliable ignition. I am also an amateur radio operator and know when an MSD is nearby (or just about any Ford) because my radios go ape with noise. Just my experiences. I am not an engineer but I do have patents in circuits using op amps so I know enough to get in trouble. Craig
Re: Orange box ???
[Re: RapidRobert]
#150721
11/16/08 08:57 PM
11/16/08 08:57 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
Even my buddy got a deal that was worse than that. He ordered a gold ecu from summit and the thing didnt even work!
& since there is no return on electrical parts he was SOL right
Right on! He was stuck with a $150 paper weight!
Re: Orange box ???
[Re: GTX MATT]
#150722
11/16/08 08:59 PM
11/16/08 08:59 PM
DusterKrazy
N.Wilkesboro,NC
Racecarbob451.Hey stick around, I am with you on this & I disagree with ironwolf's "astroturf" comment. I've been jumped on several times for no reason & what I had to do was tell them why they are full of it & that differs totally from a person respectfully dissagreeing(or addding to)another persons tech advice. There are a few members here who seem to suffer from chronic menstruation problems.
Mention 440 source or Mopar Performance parts, ESPECIALLY purpleshaft cams, and its sure to be a
Ill admit some of the MoPar stuff isnt as great as other stuff, but I kind of like the idea of using it because its almost like its factory to me, at least its made by the company that made my car. If the difference in performance is questionable Id always choose the MoPar part.
Some mopar stuff is good and some is not so good. But I LOVE mopar purpleshaft cams!
Re: Orange box ???
[Re: DusterKrazy]
#150723
11/16/08 11:41 PM
11/16/08 11:41 PM
never a complaint from my old 284/484 cam- except for the complaints I heard from the guys I beat
Re: Orange box ???
#150724
11/17/08 03:55 AM
11/17/08 03:55 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I did the same, pulled apart an old orange ECU and reverse engineered it about 10-years ago. It's pretty simply circuitry. I haven't bought any newer production mopar ignition stuff. The last Electronic ignition kit I bought, the distrubitor was assembled incorrectly to where the oil pump tab was a different position than the rotor, and the rotor to cap phaseing was way off too.. This was when Mopar was selling the conversion kits for about $100 (probbably 8+ years ago?) I have used both the orange and chrome boxes and never had one melt the potting material. The one I tore apart I thought was bad, but found later it was a wiring problem. I do use the Mallory ballast resistor, and I think they are around 0.8 ohm to 1-ohm? I have never burned one of these resistors out, but I have had two of the Mopar ballast resistors fail. Anyhow, with these ignitions, the ignition coil is doing most of the work.
