Page 3 of 3 1 2 3
Re: Converting back to a 727 trans from my 4-speed ! [Re: 493DRIVER] #1506127
11/28/13 10:42 AM
11/28/13 10:42 AM
Maryville tn
67coronetman Offline OP
Maryville tn
Thanks again scott it was great having you & jerry here i hope all is well with you and jerry have a great thanksgivng and if i can do anything to help you with the install call me plus after thanksgiving i will dig up all the pictures i have & email them to you and let jerry know his gears will be out & shipped very soon..:)
God bless you & your family.
Oh yes i found the shift i wanted.!!!!!!!!!!!!!!:)
your welcome Mark I cant wait to get this 4spd in, im looking forward to this install.
thanks again for everything keep me up dated
Old car are me......
Re: Converting back to a 727 trans from my 4-speed ! [Re: 67coronetman] #1506128
11/28/13 11:11 AM
11/28/13 11:11 AM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
Thanks Mark I will give you a ring a soon I get started on the install, I need to get heat in the garage first LOL! I will let Jerry know
Happy Thanksgiving GOD bless to you & family
Re: Converting back to a 727 trans from my 4-speed ! [Re: 493DRIVER] #1506129
12/02/13 11:23 AM
12/02/13 11:23 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Scott,
What are you going to go with, for a clutch setup?
Start a new thread in the race section if you want. We can all throw our opinions out there.
Larry
Re: Converting back to a 727 trans from my 4-speed ! [Re: LAR_414] #1506130
12/02/13 02:59 PM
12/02/13 02:59 PM
Maryville tn
Maryville tn
I ain't scott but he got a clutch & two pressure plates the clutch he got from me was a street slayer clutch from American powertrain.. Plus i had two very heavy duty built pressure plates made.
Scott,
Larry
Re: Converting back to a 727 trans from my 4-speed ! [Re: 67coronetman] #1506131
12/02/13 10:11 PM
12/02/13 10:11 PM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
Yes I was going to use the street slayer clutch & the 3 finger borg & beck pressure plate he had made, he has a big block with SR heads flowing 330 in a B body so I figure it should work in mine. my car is heavier then Marks.
Re: Converting back to a 727 trans from my 4-speed ! [Re: Jeff_383] #1506132
12/03/13 10:32 AM
12/03/13 10:32 AM
LAR_414 Offline
LAR_414  Offline
When my dad and I bought a guy's stash of 18 spline stuff, I just used an old Hays B&B and Ram bronze puck disc that came with the transmissions. I figured, that we bought it and we had it. Gave me a chance to drive it around and see what I liked or didn't like.
Then I found that the pressure plate was not flat and burned up the disc after a bunch of abuse by me.
Either way, now I know what I want and what feel and I bought a brand new B&B / Long style McLeod disc that you can even add counter weight to. I got a McLeod 600 series disc. This setup is supposed to be good to over 650hp and guys are running even more than that. Very Very streetable, as that weighs even more heavily to me!
Scott, you're doing it right. So try out what you have and go from there!
Re: Converting back to a 727 trans from my 4-speed ! [Re: 493DRIVER] #1506133
12/03/13 12:12 PM
12/03/13 12:12 PM
Maryville tn
Maryville tn
American Powertrain said the street slayer clutch is rated at 800 hp & 800 ft tq and i will say it never failed to hook for me period and you can call them they where very helpful...
Re: Converting back to a 727 trans from my 4-speed ! [Re: 67coronetman] #1506134
12/04/13 08:33 PM
12/04/13 08:33 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
That's awesome that you guys got together here on moparts and made a trade that worked for both guys. I wish that I were on the 4 speed end!!!!
I've got a fresh 727 and PTC Converter being put together if any of you other joes wanna go the TF route!!!! both units, I pay shipping!!!!
I’m listening.
Re: Converting back to a 727 trans from my 4-speed ! [Re: Big Bad Bee] #1506135
12/04/13 09:45 PM
12/04/13 09:45 PM
Maryville tn
Maryville tn
There is a guy on forbbodiesonly.com that is looking to do the same i have no idea what his stuff is like..
Re: Converting back to a 727 trans from my 4-speed ! [Re: LAR_414] #1506136
12/05/13 12:40 AM
12/05/13 12:40 AM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
Thanks Larry, i'll keep you guys posted as I work on it. it did work out well trading my TF for his 4spd Mark is a good guy met him through one of my friends, Mark ended up with my friends 66 satellite is how we hooked up. I got lot work still need to pull center out of dana to repair posi or put a spool in it? & redo my fuel sending unit may try 1/2 unit instead of a sump in my tank.
Re: Converting back to a 727 trans from my 4-speed ! [Re: 493DRIVER] #1506137
12/06/13 07:51 PM
12/06/13 07:51 PM
Maryville tn
Maryville tn
Back at you my friend .. So is it all in and going did u do a bigggggggggg burnout....... Lol.
No but really how is it going.
Re: Converting back to a 727 trans from my 4-speed ! [Re: 67coronetman] #1506138
12/07/13 07:20 AM
12/07/13 07:20 AM
Central TX
roe Offline
roe  Offline
Central TX
Im glad it all worked out for you guys with the trade. I too prefer automatics and have on in my cruiser and daily drivers.
I learned how to drive a stick when I was about 14. Now Im 28 and havent driven once since until a couple of days ago. I was rusty at first but it came back pretty quickly. Now Im thinking that I want a little beater just so I can enjoy shifting gears again. It was fun!!!
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Converting back to a 727 trans from my 4-speed ! [Re: roe] #1506139
12/07/13 11:14 AM
12/07/13 11:14 AM
Maryville tn
Maryville tn
Yes sir it is lots of fun and i really enjoyed it while i had it i guess you could say i have always been a Automatic man yes it would be fun to have a beater car to go thru the gears. Yea jerry & scott are really good guys for sure..
roe
Re: Converting back to a 727 trans from my 4-speed ! [Re: 67coronetman] #1506140
12/08/13 11:41 PM
12/08/13 11:41 PM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
Nope its bin to cold I need to get some heat in my garage, I did get the 70 pedals bead blasted & painted and back together greased ready to go in.
i'm starting on the column next.
Re: Converting back to a 727 trans from my 4-speed ! [Re: 493DRIVER] #1506141
12/09/13 02:03 AM
12/09/13 02:03 AM
Maryville tn
Maryville tn
Awesome i got my floor al welded up & the trans & stall in so far..
Re: Converting back to a 727 trans from my 4-speed ! [Re: 67coronetman] #1506142
12/09/13 09:47 PM
12/09/13 09:47 PM
PGH. PA.
493DRIVER Offline
493DRIVER  Offline
PGH. PA.
Nice don't have much more to do, shifter & gears & you will be ready
Re: Converting back to a 727 trans from my 4-speed ! [Re: 493DRIVER] #1506143
12/10/13 12:56 AM
12/10/13 12:56 AM
Maryville tn
Maryville tn
Almost i put the brake pedal back in today & the starter & ground strap.should have trans lines in by weeks end i hope and all ran just figuring how i want them plus waiting on shifter to be pulled from the car and shipped to me may be after the first of the year..
Page 3 of 3 1 2 3
