Re: Converting back to a 727 trans from my 4-speed !
[Re: Plum440]
#1506094
09/24/13 11:04 PM
09/24/13 11:04 PM
Posts: 5,161 CT
GTX MATT
CT
4 Speed vs Torqueflite such a hard choice
[Re: ademon]
#1506096
09/25/13 05:15 PM
09/25/13 05:15 PM
Posts: 768 Maryville tn
67coronetman
Maryville tn
Thanks for the info i have talked to them but still searching. Quote:
Call a good trans shop like cope. and a hi 4500rpm stall is a lot of fun!!!
Old car are me......
[Re: GTX MATT]
#1506101
11/14/13 12:18 PM
11/14/13 12:18 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
Don't trade him unless you want junk
[Re: DGS]
#1506113
11/21/13 08:58 AM
11/21/13 08:58 AM
67coronetman
Maryville tn
Very well put. Quote:
Theoretically the 4-speed should yield an advantage over the auto as it has a lower first gear (2.66 vs 2.45) and less drive train loss (not sure on the numbers but I heard 5% vs 10-15%).
However shifting as fast as an auto is quite challenging..
[Re: 493DRIVER]
#1506124
11/24/13 08:06 PM
11/24/13 08:06 PM
67coronetman
Maryville tn
I will and you do the same my friend...
[Re: 493DRIVER]
#1506127
11/28/13 10:42 AM
11/28/13 10:42 AM
67coronetman
Maryville tn
[Re: 67coronetman]
#1506134
12/04/13 08:33 PM
12/04/13 08:33 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
That's awesome that you guys got together here on moparts and made a trade that worked for both guys. I wish that I were on the 4 speed end!!!! I've got a fresh 727 and PTC Converter being put together if any of you other joes wanna go the TF route!!!! both units, I pay shipping!!!!
I’m listening.
[Re: 493DRIVER]
#1506137
12/06/13 07:51 PM
12/06/13 07:51 PM
67coronetman
Maryville tn
Back at you my friend .. So is it all in and going did u do a bigggggggggg burnout....... Lol. No but really how is it going. Quote:
Thanks Larry, i'll keep you guys posted as I work on it. it did work out well trading my TF for his 4spd Mark is a good guy met him through one of my friends, Mark ended up with my friends 66 satellite is how we hooked up. I got lot work still need to pull center out of dana to repair posi or put a spool in it? & redo my fuel sending unit may try 1/2 unit instead of a sump in my tank.
[Re: 67coronetman]
#1506138
12/07/13 07:20 AM
12/07/13 07:20 AM
Posts: 3,344 Central TX
roe
Central TX
Im glad it all worked out for you guys with the trade. I too prefer automatics and have on in my cruiser and daily drivers. I learned how to drive a stick when I was about 14. Now Im 28 and havent driven once since until a couple of days ago. I was rusty at first but it came back pretty quickly. Now Im thinking that I want a little beater just so I can enjoy shifting gears again. It was fun!!! roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: roe]
#1506139
12/07/13 11:14 AM
12/07/13 11:14 AM
67coronetman
Maryville tn
Yes sir it is lots of fun and i really enjoyed it while i had it i guess you could say i have always been a Automatic man yes it would be fun to have a beater car to go thru the gears. Yea jerry & scott are really good guys for sure.. Quote:
roe
[Re: 67coronetman]
#1506140
12/08/13 11:41 PM
12/08/13 11:41 PM
Posts: 184 PGH. PA.
493DRIVER
PGH. PA.
Nope its bin to cold I need to get some heat in my garage, I did get the 70 pedals bead blasted & painted and back together greased ready to go in. i'm starting on the column next.
[Re: 493DRIVER]
#1506141
12/09/13 02:03 AM
12/09/13 02:03 AM
67coronetman
Maryville tn
Awesome i got my floor al welded up & the trans & stall in so far..
[Re: 493DRIVER]
#1506143
12/10/13 12:56 AM
12/10/13 12:56 AM
67coronetman
Maryville tn
Almost i put the brake pedal back in today & the starter & ground strap.should have trans lines in by weeks end i hope and all ran just figuring how i want them plus waiting on shifter to be pulled from the car and shipped to me may be after the first of the year..
