451 ? #1503299
09/17/13 08:14 PM
09/17/13 08:14 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Do all 451 stroker pistons used with a 440 rod have the oil control ring partially into the wrist pin hole??
Re: 451 ? [Re: ccdave] #1503300
09/17/13 08:48 PM
09/17/13 08:48 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
No. None of them should. The 451 with the 440 rod uses a piston with 1.32 compression height. Plenty of space between the pin and the oil ring.
Re: 451 ? [Re: ccdave] #1503301
09/18/13 11:13 PM
09/18/13 11:13 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Not a problem either way.
Re: 451 ? [Re: ccdave] #1503302
09/19/13 12:00 AM
09/19/13 12:00 AM
It depends on which block, low deck or RB B motors(400 blocks) probally, 440 blocks shouldn't
Re: 451 ? [Re: Cab_Burge] #1503303
09/19/13 01:15 AM
09/19/13 01:15 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
a 451 doesn't but a 496 does.
Re: 451 ? [Re: rebel] #1503304
09/19/13 11:42 PM
09/19/13 11:42 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
We're talkin in a 400 block
Re: 451 ? [Re: ccdave] #1503305
09/20/13 12:01 AM
09/20/13 12:01 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
as mentioned none of them should, normally a 471 and above using a RB rod will be in the oil ring
Re: 451 ? [Re: ccdave] #1503306
09/20/13 12:13 AM
09/20/13 12:13 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
1.12 compression height pistons require an oil ring support rail, 400/498. 400/451 use a 1.32 ch piston and work like anything else.
Mopar to the bone!!!
Re: 451 ? [Re: 72Swinger] #1503307
09/20/13 06:52 PM
09/20/13 06:52 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Some info from Muscle Motors on their stroker kits for 400 blocks.
400 Kits
400/451”: 3.75 stroke x 6.76 rod, 4.375 bore 1.320 CH piston.
One of the original stroker kits for big block Mopars. These kits are noting more than a 440 built with a really light piston. 3.75 x 6.76 (440 stroke and rod) but because the block is 3/4”shorter, the piston is ¾” shorter and literally ½ the weight.
400/470”: 3.91 stroke x 6.700 rod, 4.375 bore 1.320 CH piston.
This is one of those kits that works better than it should. When using stock port window cylinder heads (factory, Edelrock RPM, Stage VI) this is the PERFECT combination. Good amout of cubes, super lite weight rotating assembly, great rod ratio, just a dynamite combo.
400/511”: 4.25 stroke x 6.535 rod, 4.375 bore 1.320 CH piston.
This combo has a piston with a 1.320 compression height. What that all means is that it stops the piston at zero deck on an unmachined block.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
