Little Red Express question #1501729
09/15/13 12:29 PM
09/15/13 12:29 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Going to look at a 78 LRE and was curious. Do the engine blocks on these have the VIN stamped in them? Or how do I tell if it's the original engine? Also what rear ends did they put under these? 8.75? Any other thing to look for to tell if it's an original LRE? Thanks
Re: Little Red Express question [Re: 440forPOWER] #1501730
09/15/13 12:51 PM
09/15/13 12:51 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
8.75 stopped in 74. It'll should have a 9.25(12bolt cover) Generally if its a 360 it will most likely very original but not always
Re: Little Red Express question [Re: 76dodgeboy] #1501731
09/15/13 03:55 PM
09/15/13 03:55 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
Engine should not have the VIN on it
5th digit of the VIN should be an S
As stated should be 9-1/4 rear
The VIN should be on the passengers side frame rail
Check out Details here
http://lilreddad.com/Misc.html
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
