2001 Dodge Ram 2500 2wd wheel bearing replacement? #1500689
09/12/13 11:53 PM
09/12/13 11:53 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
The front wheel bearing on dad's 2001 Ram CTD is going out. It is a 2wd with four wheel disc brakes/abs. I noticed that on the Autozone website that there is a bearing and then there is a hub assembly.
Do you replace the hub assembly or can you just replace the bearing??
Re: 2001 Dodge Ram 2500 2wd wheel bearing replacement? [Re: DusterKrazy] #1500690
09/13/13 12:29 AM
09/13/13 12:29 AM
IL,USA
bdusted440 Offline
bdusted440  Offline
IL,USA
Replace the hub complete.And do NOT use an autozone hub. It's a pita to do as it is. You don't want to do it twice.
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
1970 v code superbee
