Re: Stuck throttle shaft
[Re: Faust]
#1500594
09/12/13 09:29 PM
09/12/13 09:29 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
My '67 Coronet, '66 383 with the carter 2 bbl, has been in hibernation for a few years and I am trying to fire it up. My problem is the throttle shaft is frozen. I have been spraying PP Blaster for a few days, and "tapping" the shaft with a very light hammer. No luck.
Any suggestions?
dot 3 brake fluid. you would never think so huh? 1 try and I bet your hooked...
[Re: TJP]
#1500596
09/12/13 11:14 PM
09/12/13 11:14 PM
Posts: 2,354 Massachusetts
Faust
Massachusetts
Pull the carb, soak the lower portion in a mix of 50/50 acetone / ATF for a day or two. report back
I have some of that mixed up, it has worked well before. It does take a day.
[Re: Faust]
#1500597
09/13/13 12:43 AM
09/13/13 12:43 AM
Posts: 172 IL,USA
bdusted440
IL,USA
50/50 atf kerosene. works awesome.
currently own 1976 duster deluxe 1974 gold duster 1993 Dakota sport 2000 caravan 2002 Durango 1970 v code superbee
