Starter relay...What goes on this terminal
#1499982
09/11/13 09:44 AM
09/11/13 09:44 AM
Posts: 5,890 Athens, Greece
Pyper70
Athens, Greece
I am looking at the FSM and the picture below (with arrow) points to the one terminal on the starter relay...this goes to the harness which leads into the 4 terminal bulkhead, car is a 1972 Roadrunner 440, 4-spd.
The previous owner had this hooked up directly to (-) post on the battery. FSM states that this goes to the transmission on the clutch switch. I am assuming you have to depress the clutch in order to turn the car over. How much damage is there with the ground cable being connected to this terminal?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Starter relay...What goes on this terminal
[Re: Pyper70]
#1499983
09/11/13 10:00 AM
09/11/13 10:00 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
No damage at all. It is designed to be grounded threw the Neutral Safety Switch on an automatic car and the switch on the clutch pedal on a 4 peed car. Eather way it goes to the - side of the battery .
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: Jim_Lusk]
#1499986
09/11/13 11:43 AM
09/11/13 11:43 AM
Pyper70
Athens, Greece
I see....and this is why it pays to ask on Moparts than look at FSM's and pull your hair out..
[Re: Pyper70]
#1499987
09/11/13 11:58 AM
09/11/13 11:58 AM
RapidRobert
X2 what Jim said. In fact it'd be much cleaner/easier to use a female connector and a ring terminal & several inches of wire & just connect it to the holddown bolt.
[Re: RapidRobert]
#1499990
09/11/13 05:28 PM
09/11/13 05:28 PM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
Just a side note. The older cars (my 69 Road Runner, 4 speed for example) has the tab soldered tot he casing already. I think auto cars had the nuetral start switch wired to the tab.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#1499991
09/11/13 07:36 PM
09/11/13 07:36 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Correct. The clutch switch was only used for a few years. I've owned a few manual trans FWD Mopars. None of them had a clutch switch...
[Re: Magnum]
#1499993
09/12/13 02:19 PM
09/12/13 02:19 PM
Jim_Lusk
Fresno, CA
As for a thrust bearing, it is a factor but totally overrated.
Nope, been there had to replace the bottom end for it. If a guy can't manage to put the trans in nuetral and put the left foot on the brake with the right foot on the gas he shouldn't own a three-pedal car...
[Re: Jim_Lusk]
#1499994
09/12/13 02:36 PM
09/12/13 02:36 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I agree its the ground.My 65 dosent have any N switch as it a 4 speed factory.I start in with clutch in and have been for 44 years.Never had a thrust bearing problem.My wire goes to ground.Newer autos have the N in the NR switch on the trans.Middle wire is ground.Almost every new car with manual has a N switch on the clutch.I guess someone better tell the engineers they are screwed up and ruining engines that go 200K or more.Rocky
Chrysler Firepower
[Re: 540DUSTER]
#1499996
09/12/13 03:17 PM
09/12/13 03:17 PM
Challenger 1
Cincinnati, Ohio
My good friend was working on his car in the garage.His wife was helping him with an electric problem.He tells her to turn the key on,she starts the car in gear.He ended up in the emer. room with 4 broken ribs.There was a nice hole in the drywall where he went thru.Its a good thing he was between the studs.There is a reason for those switches.
I agree, they should be used and it's very dangerous not using it.
[Re: Jim_Lusk]
#1499998
09/12/13 07:51 PM
09/12/13 07:51 PM
Pyper70
Athens, Greece
I grounded it for now....until I have time to crawl under the car and see whats going on under there...I suspect there is not clutch switch...I found the entire harness (square 4-terminal disconnected and thrown on top of the bellhousing with wire nuts....
Eventually I will get him to buy the right parts so it can be a safe car...no matter how much I drive this 4spd...I am really thankful my father bought the Charger in a 727 configuration
[Re: Pyper70]
#1499999
09/12/13 08:48 PM
09/12/13 08:48 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
I removed my clutch switch on my 70 Cuda because of the thrust bearing concern. Think about when you're working on your car and for some reason have to crank and crank, thrust bearings don't put up with that for long. Also, say you have the switch wired up. You get in the habit of depressing the clutch to start, but the absentminded (which is what this safety feature is designed to guard against) then THINKS his car is in neutral and quickly releases the clutch on a RUNNING engine, not realizing its in gear. Nope, I prefer the pre-ignition check to ensure I'm in neutral thank you.
[Re: therocks]
#1500000
09/13/13 02:14 AM
09/13/13 02:14 AM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
Hate to mention is here, since it's a Mopar forum but ya many cars, including their thrust bearing, go the distance with the clutch pedal depressed for starting. Had 88 Mustang with 380,000kms. The body rusted before the engine shown any signs of wear. Out in the driveway today is a 2006 International Harvester Dt466. It's seen 600,000kms of starting with the pedal to the floor. The spring pressure from it's clutch has worn out more linkage parts than tires and it's oil pressure is still 40psi hot, just like new.
