Re: 37 Plymouth PU Ressurection.
[Re: AZ_A12_BEE]
#1499029
09/10/13 11:29 AM
09/10/13 11:29 AM
Posts: 1,509 AZ
Mike P
AZ
I have the original fuel tank from my 37 Dodge PU that should be the same as what was original to your truck. I believe it is still solid. You are welcome to it.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: AZ_A12_BEE]
#1499031
09/10/13 04:06 PM
09/10/13 04:06 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Cardboard template to cut a 1 inch piece of particle board to mount seat on.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#1499032
09/10/13 07:31 PM
09/10/13 07:31 PM
Posts: 1,509 AZ
Mike P
AZ
It won't be going anywhere. I am going the old beer keg in the bed route. The stock location for the tank can be problematic for dual exhaust (somewhat the same layout as the under bed tanks on the 70s D100s).
[Re: AZ_A12_BEE]
#1499034
09/10/13 09:57 PM
09/10/13 09:57 PM
AZ_A12_BEE
Dreaming of the 808
Particle board seat base finished, ready for seat back that is bolted on and hinged so I can access the rear seat area for my battery,
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499036
09/10/13 10:00 PM
09/10/13 10:00 PM
AZ_A12_BEE
Dreaming of the 808
I hinged the particle board base so I can access the area under the seat for storage
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499037
09/10/13 10:08 PM
09/10/13 10:08 PM
AZ_A12_BEE
Dreaming of the 808
Seat complete, back folds forward to access area behind seat for battery
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499038
09/12/13 05:34 PM
09/12/13 05:34 PM
AZ_A12_BEE
Dreaming of the 808
Found a donor truck for the rear leaf springs, made the deal and will pull them next week, $45 per side, a great deal
37 Plymouth PU
[Re: Supercuda]
#1499040
09/12/13 07:36 PM
09/12/13 07:36 PM
AZ_A12_BEE
Dreaming of the 808
I was thinking this would be a good opportunity to update the rear leafs. Not sure on trucks, but pass cars of that era have some honking thick spring packs that are 2" wide. That donor being a tow truck of some sort probably had even stouter spring packs.
But the price is good.
Theses springs in these years are only 1 3/4 inch wide, the ones on this tow truck have as many leafs as mine, I will post a side by side pic when I do the swap
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499041
09/13/13 09:27 PM
09/13/13 09:27 PM
AZ_A12_BEE
Dreaming of the 808
Looks like I'm going to use the gas tank out of a 93 Geo tracker, a little small at 11 gallons but it will fit with very little fabrication
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499042
09/17/13 10:51 PM
09/17/13 10:51 PM
AZ_A12_BEE
Dreaming of the 808
Got my fuel tank today, it's out of a 93 Geo Sidekick, mounting it will be a breeze.
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499043
09/18/13 05:51 PM
09/18/13 05:51 PM
AZ_A12_BEE
Dreaming of the 808
Pulled my replacement springs this morning, took about 3 hours
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499045
09/20/13 05:56 PM
09/20/13 05:56 PM
AZ_A12_BEE
Dreaming of the 808
Got her to crank over today, hopefully get her started/running tomorrow
37 Plymouth PU
