Re: 37 Plymouth PU Ressurection.
[Re: RodStRace]
#1499230
12/03/14 04:07 PM
12/03/14 04:07 PM
Posts: 19,239 north of coder
moparx
Got these ones out, I'm going to replace all the screws with new Philips style screws
I would highly recommend torx head, better grip with the driver, both in and out.
YES, or good quality Allens. Phillips are worse than flat!
absolutely ! also, make sure you don't get the replacements a couple or so too long of thread length, as this will cause multiple problems with the glass/framework install.
[Re: 36dodge]
#1499231
12/22/14 01:50 AM
12/22/14 01:50 AM
Posts: 1,572 Jacksonville Florida
elitecustombody
Good to see progress...moving right along Wanna come work on mine Got two of them 36 & 37 Dodges
Anyone have a spare set of rear fenders for 36-38 Dodge,37-38 Plymouth truck?
[Re: 36dodge]
#1499233
12/24/14 01:27 AM
12/24/14 01:27 AM
elitecustombody
Stefan.....I thought you sold yours?
Michael, I sold the 36 Dodge and 37 PT50, still have complete 38 and partial late 35 I'm gathering parts for
[Re: elitecustombody]
#1922214
09/30/15 12:58 AM
09/30/15 12:58 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Picked back up on the 37 to start driving it again. Welded up 31 holes in the lower firewall and reinstalled it
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#1922217
09/30/15 01:01 AM
09/30/15 01:01 AM
AZ_A12_BEE
Dreaming of the 808
Done and reinstalled
37 Plymouth PU
[Re: AZ_A12_BEE]
#1922219
09/30/15 01:05 AM
09/30/15 01:05 AM
AZ_A12_BEE
Dreaming of the 808
Made a new metal floorboard to replace the wood one, I used 3/4 square tubing and 14 guage flat steel, welded the frame then the flat plate
37 Plymouth PU
[Re: AZ_A12_BEE]
#1922227
09/30/15 01:10 AM
09/30/15 01:10 AM
AZ_A12_BEE
Dreaming of the 808
Replaced crappy transmission support with a new one I bought from Speedway Motors
Old crappy one and new one
37 Plymouth PU
[Re: AZ_A12_BEE]
#1922229
09/30/15 01:12 AM
09/30/15 01:12 AM
AZ_A12_BEE
Dreaming of the 808
Installed, just need to bolt it down and weld it up
37 Plymouth PU
[Re: poorboy]
#1922996
10/01/15 01:22 AM
10/01/15 01:22 AM
AZ_A12_BEE
Dreaming of the 808
So if you weld those flanges to the crossmember, will you still be able to remove it? How will it drop down with the bottom flanges on the frame rails? Curious minds want to know. Gene f Gene, cross member is only bolted to the frame rails, plus frame widens towards the rear so it can slide back to remove trans if needed
37 Plymouth PU
[Re: AZ_A12_BEE]
#1923532
10/01/15 05:46 PM
10/01/15 05:46 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Might want to just tack it together and verify it's removable before you commit. Better to verify that it works now than assume it does and find out later it don't.
[Re: AZ_A12_BEE]
#1923893
10/02/15 01:18 AM
10/02/15 01:18 AM
AZ_A12_BEE
Dreaming of the 808
Got my seat back and installed
37 Plymouth PU
#1923895
10/02/15 01:24 AM
10/02/15 01:24 AM
AZ_A12_BEE
Dreaming of the 808
New gas pedal ready to install
37 Plymouth PU
