M Body handling improvements #1498923
09/09/13 12:22 PM
09/09/13 12:22 PM
DC, MD Suburbs
440PURSUIT Online content OP
440PURSUIT  Online Content OP
DC, MD Suburbs
Just scored a clean 1980 Diplomat 2 door.
What would be some good improvements to this car?
Cop Parts or aftermarket?
Re: M Body handling improvements [Re: 440PURSUIT] #1498924
09/09/13 12:23 PM
09/09/13 12:23 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
1980 or 1990? I think the last year for the M was 89
A new iron curtain drawn across the 49th parallel
Re: M Body handling improvements [Re: 440PURSUIT] #1498925
09/09/13 12:23 PM
09/09/13 12:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You mean 80?
Cop stuff, if you can find it, is usually cheap. Firm Feel makes some stuff for them, not cheap but quality.
I believe Mopar Muscle had a series on upgrading the M some years ago. Finally, www.dippy.org is a good resource.
Don't be the exception.
Re: M Body handling improvements [Re: 67autocross] #1498926
09/09/13 12:24 PM
09/09/13 12:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Got to be 80, 81 was the last year of the 2 door I believe.
Re: M Body handling improvements [Re: Supercuda] #1498927
09/09/13 12:30 PM
09/09/13 12:30 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Next question how much do you want to spend?
Re: M Body handling improvements [Re: 440PURSUIT] #1498928
09/09/13 01:39 PM
09/09/13 01:39 PM
DC, MD Suburbs
DC, MD Suburbs
1980
Re: M Body handling improvements [Re: 440PURSUIT] #1498929
09/09/13 01:43 PM
09/09/13 01:43 PM
DC, MD Suburbs
DC, MD Suburbs
Wow, my iPhone did some nasty Spell changes.
I would want to be conservative spending. Other muscle projects take precedence.
Re: M Body handling improvements [Re: 440PURSUIT] #1498930
09/09/13 02:08 PM
09/09/13 02:08 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Solid K member mounts and good front shocks would be my first items.
Re: M Body handling improvements [Re: 67autocross] #1498931
09/09/13 08:55 PM
09/09/13 08:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://firmfeel.com/fmj.htm
A god place to look around
Re: M Body handling improvements [Re: 440PURSUIT] #1498932
09/17/13 12:43 AM
09/17/13 12:43 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
How crazy are you looking to get? The weakest part of the entire package are the torsion bars in my opinion. I've got a Fifth Avenue that I pretty much did everything to and still wasn't very happy with it until I put new bars in it.
Cop sway bars, frame ties, and modifying the power steering pump will give you the biggest improvement (providing everything else is straight) for the least amount on money spent. If you really want to make it handle:
-FF 300# torsion bars
-FF aluminum K frame biscuits
-Cop 1 1/8" front sway bar (civy is only 1 1/16") with poly bushings
-Cop 3/4" rear bar with poly bushings
-Frame ties
-5 leaf rear springs
-Dump the ISO setup in the rear and run B-body shock plates
-Bilstein shocks on all four corners
-11/16" tie rods
-Modify the stock power steering pump regulator valve to turn down the pressure
-Decent tires
This is what I did to my Fifth and it handles like it's on rails now.
