When should a 180* tstat start to open? #1498645
09/08/13 11:29 PM
09/08/13 11:29 PM
Minnesota
Mad Accountant Offline OP
Minnesota
I have two supposed 180* tstats, one the JEGS brand #555-53211 and one local parts house brand. Neither one even start to open until about 190 (they're in a pot on my stove). At 190 they open a hair, 200 about halfway, all the way about 208. As the water cools, they both start to close about 190; the parts house tstat is closed about 185, and the JEGS is still open a crack at 180. I've done this three times, making sure to raise the water temp very slowly, in case the springs have some lag as they react to the temp (wife is looking at me like i belong in the nut house). The thermometer is spot on, Iv'e actually used two and cheked them both first.
Is the way these tstats react normal, or am I just unlucky?
Re: When should a 180* tstat start to open? [Re: Mad Accountant] #1498646
09/08/13 11:41 PM
09/08/13 11:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
180* stat won't open until it hits 180*.
Re: When should a 180* tstat start to open? [Re: Mad Accountant] #1498647
09/08/13 11:46 PM
09/08/13 11:46 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
The normal Start to Open range for a 180° thermostat is 177° to 184°. The tricky part is that STO is defined as an opening of .003", which you can't measure. It will be open all the way by about 204°. You can't measure it that accurately on the stove, because it has to sit at that temperature for a few minutes. There is a lag as the water temperature changes.
The spring has absolutely nothing to do with the operating temperature, which is controlled by expansive wax inside the bronze cup.
Steve
Someday I'll have another C-body.
Re: When should a 180* tstat start to open? [Re: Mad Accountant] #1498648
09/09/13 12:37 AM
09/09/13 12:37 AM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
thanks for the "wife is looking at me like i belong in the nut house" line, i got a nice chuckle out of that .
Re: When should a 180* tstat start to open? [Re: SteveS] #1498649
09/09/13 03:58 PM
09/09/13 03:58 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
If the initial opening is so small,
and since most vehicles coolant temperature
does stay pretty close to the 180 Tstat rating,
not near the 204 degree full opening
i guess that means that much of the time during lazy part throttle driving
the annular opening is only ten to thirty thousandths "high" ?
Re: When should a 180* tstat start to open? [Re: 360view] #1498650
09/09/13 06:57 PM
09/09/13 06:57 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
Kinda.
A couple of things come into play. First, the wax expansion is non-linear. Second, the test dude is going to look at three temperatures: 177°, 184°, and 204°. I'm using some typical Stant numbers here. It shouldn't move at 177°. At 184° you will probably see something averaging about .030" to .060". As the temperature rises a little from there, the expansion curve gets steeper. A small temperature change means a larger amount of expansion. The expansion occurs over about 15°, and then the curve flattens out again. By 197° or so, it's done. At that point, the thermostat is no longer controlling temperature.
There is some lag with temperature changes, because the heat needs to propagate through the entire wax cavity. There is copper and/or other materials blended with the wax to help with heat transfer.
The same ranges apply to other temperatures, too. The wax is blended according to the desired temperature and expansion characteristics.
Steve
Re: When should a 180* tstat start to open? [Re: Mad Accountant] #1498651
09/09/13 07:54 PM
09/09/13 07:54 PM
Minnesota
Minnesota
Thanks for the info. Sounds like what I have is working the way it is supposed to. Didn't know it was wax that operated the tstat, thought the spring was one of those bimetallic jobs.
Re: When should a 180* tstat start to open? [Re: Mad Accountant] #1498652
09/09/13 08:21 PM
09/09/13 08:21 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
What many people do not understand is that the thermostadt is not just simply an open/close water flow switch. The marked temperature is when it starts to open, and typically it takes another 5-7% of increased water temperature to open fully...
A 195 F degree thermostadt will start to open around 195 F but will not be fully open until about 205-208 F degrees. The real question is How much time? is required for the thermostadt to be fully open.. This is directly dependent upon several factors including:
Outside air temperature
Engine loads
Engine compression
Fuel octane rating
Amount of timing
Radiator capacity
Airflow through the radiator
Vehicle speed
Just my $0.02..
Re: When should a 180* tstat start to open? [Re: Mad Accountant] #1498653
09/09/13 08:24 PM
09/09/13 08:24 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
Probably 99% of the "defective" thermostat returns work perfectly, regardless of whether they come from consumers and jobbers (NAPA, Carquest, etc.) or from new car dealers!
In other words, the problem is usually with another cooling system component, or the installer.
Steve
Re: When should a 180* tstat start to open? [Re: SteveS] #1498654
09/09/13 09:43 PM
09/09/13 09:43 PM
Minnesota
Minnesota
Probably the installer.........guilty!
Re: When should a 180* tstat start to open? [Re: Mad Accountant] #1498655
09/10/13 09:11 AM
09/10/13 09:11 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I installed a brand new thermostat in a DT 466 diesel engine last week that was new from the dealer and it did not work properly. I had to change it out Friday and now all is well.
Sucks for me as I had to do the job twice and not get paid for it.
Re: When should a 180* tstat start to open? [Re: Mad Accountant] #1498656
09/10/13 09:15 AM
09/10/13 09:15 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Mine usually shows opening about 5 degress over the rating
Re: When should a 180* tstat start to open? [Re: SteveS] #1498657
09/10/13 10:35 AM
09/10/13 10:35 AM
USA
3
360view Offline
360view  Offline
3
USA
In Chryslers original press release about the then-new iron V10 Ram pickup engine, they made these claims about the $35 thermostat used:
quote
A heavy-duty truck engine block cooling system and thermostat minimized low-temperature piston wear and oil consumption by allowing the cylinder walls to warm up gradually and expand uniformly. The truck-type thermostat opened in a smooth continuous manner because it had four times the working area of a passenger car thermostat. A conventional thermostat released bursts of chilled water during warm-up that distorted the cylinder walls and causeed wear and high oil consumption. The thermostat had a cylindrical valve element with an O-ring seal to assure smooth consistent operation. It was mounted in a molded plastic housing at the front of the engine.
unquote
Is the V10 thermostat a better design?
original at
http://www.allpar.com/mopar/V10.html
Re: When should a 180* tstat start to open? [Re: 360view] #1498658
09/11/13 10:24 PM
09/11/13 10:24 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
I guess Ma was saying that all of their other cooling systems sucked?
That top bypass design has been used by people like Mack and Detroit Diesel for years. The coolant flow is constant, and the thermostat directs the flow back into the engine, and into the radiator, and the percentage varies with the temperature. Pretty much just like any other thermostat. They might mix better, but I think they could have done the same thing with a more conventional bypass blocking thermostat.
Steve
Re: When should a 180* tstat start to open? [Re: SteveS] #1498659
09/12/13 11:06 PM
09/12/13 11:06 PM
Minnesota
Minnesota
Put the JEGS tstat in it and fired it up. Sure enough, gauge never went over about 183! Guess it works as advertised even though it didn't look like it on the stove. Who knew? Oh yeah, you guys did. Thanks to everyone who chimed in.
