#14972 - 03/11/05 11:42 AM Shrinking Sheet metal !! Heat/ice or shrink hamer
Clair Offline
Pot Stirrer #4
Loc: Cornfield. IN
Anybody use a shrinking hammer or heat and ice to pull some stretched metal back.
Have a fender that took a pretty good hit and have it looking pretty good but still have some high spots/stretched metal.
Is the $40 shrinking hammer worth the money.
Has anybody used heat and water/ice?
Anybody try these methods and what was the outcome
Thanks Clair.
Edit I use to just mud it in but would too really try for the best panel this time
#14973 - 03/11/05 12:07 PM Re: Shrinking Sheet metal !! Heat/ice or shrink ha [Re: Clair]
The shrinking hammer will work to a certain degree. It depends on how "high" your problem area is. I sometimes use the torch and a rag soaked in ice water to pull them back. You start on the outside edge of the high spot and work your way in. I also have a heating/shrinking tip for my stud gun. It works wonders on the little ones, then finish with a body file. If the area is radically distorted and appears as a "bubble" from too much hammer work, I sometimes remove some material by slicing it in the middle with a thin cutting wheel, hammer and dolly it flat, then weld the split back. I realy hate using filler and sometimes go overboard to avoid using it. Hope this helps.
#14974 - 03/11/05 12:08 PM Re: Shrinking Sheet metal !! Heat/ice or shrink hamer [Re: Clair]
RichV Offline
Loc: Seattle WA
I think heat is the best method for shrinking. I haven't had much luck with a shrinking hammer.
#14975 - 03/11/05 12:10 PM Re: Shrinking Sheet metal !! Heat/ice or shrink hamer [Re: Clair]
Shrink hammer worked better for me. Ice only worked on the hail dents, but I'm not a bodyman.
#14976 - 03/11/05 12:18 PM Re: Shrinking Sheet metal !! Heat/ice or shrink ha [Re: Clair]
Also, one of these will make an average man into a metalworking genius on the small dents.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=43996&item=4534622885&rd=1
#14977 - 03/11/05 12:38 PM Re: Shrinking Sheet metal !! Heat/ice or shrink hamer [Re: Clair]
Clair Offline
Pot Stirrer #4
Loc: Cornfield. IN
Good info muddshark
Do you have that tool ???
I slit/reweld the one dent/ to stop it from OIL canning.
That worked well.
The area I am currently working is not that bad will try the heat/ice and see how that does.
Yes I basicly over streached it from beeting it out.
#14978 - 03/11/05 12:46 PM Re: Shrinking Sheet metal !! Heat/ice or shrink ha
stateline Offline
Loc: Under the big sky
A stud gun with a shrinking tip works real well for the average guy . You can use an air hose instead of water to shrink with too.
#14979 - 03/11/05 12:51 PM Re: Shrinking Sheet metal !! Heat/ice or shrink ha [Re: stateline]
Clair Offline
Pot Stirrer #4
Loc: Cornfield. IN
I was not aware they made a shrinking tool for stud guns
What’s a good gun that will last/work well?
I have alway wanted 1 and now may be the time !!!!
#14980 - 03/11/05 01:05 PM Re: Shrinking Sheet metal !! Heat/ice or shrink ha [Re: Clair]
I've got a Uni-spotter 4500. I've had it for years and have abused it, dropped it and it's still cookin'. I also have a couple of bullseye picks in different sizes. Fix one fender with one and you'll wonder how you ever lived without one. Same for the stud gun.
#14981 - 03/14/05 02:50 PM Re: Shrinking Sheet metal !! Heat/ice or shrink hamer *DELETED* [Re: Clair]
Clair Offline
Pot Stirrer #4
Loc: Cornfield. IN
Post deleted by Clair
25,708 Registered Members
196,872 Topics
69 Road Runner
by kwhmopar1
7 minutes 49 seconds ago
70 AAR Cuda Exhaust
by Evil Spirit
Today at 10:34 AM
2009 SRT8 - low miles
by Neil
Today at 09:38 AM
Low-Buck Dart Console Rebuild With Classic Industries
by Rustymuscle
Today at 09:36 AM
