Rocker problems with head studs #14967
03/11/05 02:35 PM
03/11/05 02:35 PM
Anonymous OP
Anonymous OP
I just tore down the top of the new TT340 after finding that in the first 1000 miles, the rockers were already starting to gall up. I had checked them because I was concerned that the studs may be blocking the oil passage to rocker shafts, as the studs are not relieved like the factory head bolts are.
When I removed the valve covers, 3 of the rockers on one side had no oil puddled in the rocker, although you could see some oil had made it there, but not much. See the attachment. I took of the rockers and all were scarred up quite a bit, especially for so few miles.
I pulled the heads and did a flow test on the bench to see how much oil could get by the stud compared to the factory bolt. Depending on the location of the stud in the .050 oversize hole, flow could drop to as little as 15% of that of the factory bolt.
I relieved the area of the head bolt hole in the head between the two oil passages by about .060 and retested the flow, which went up to 85% of the flow of the factory bolt. It does appear that the studs can significantly restrict the oil to rockers, but it can be very variable, depending on where in the hole the stud locates, based on tolerances. The rollers that most folks run when they have a studded engine may be less suseptible and help explain why it has not been seen as a big problem by many.
I would recommend that if you are using studs, to relieve the headbolt hole between the passages, as it is easy and good insurance.
Re: Rocker problems with head studs #14968
03/11/05 02:38 PM
03/11/05 02:38 PM
Anonymous OP
Anonymous OP
The damage.
Re: Rocker problems with head studs #14969
03/11/05 03:15 PM
03/11/05 03:15 PM
Anonymous OP
Anonymous OP
Bummer dude.
But great info on those studs.
Say man, what's up with those crazy exhaust tubes, dude?
Oh, it's a TURBO motor. I gotcha!
Re: Rocker problems with head studs #14970
03/11/05 03:15 PM
03/11/05 03:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
good heads up . what made you go looking for this ?
Re: Rocker problems with head studs [Re: JohnRR] #14971
03/11/05 04:59 PM
03/11/05 04:59 PM
Anonymous OP
Anonymous OP
The previous motor showed more wear in the rockers than I would have expected after 40K miles, so I was very aware of oiling and passages as I put together the new motor. It was very obvious when I put the studs in the new motor that they were running to the side of the hole that would restrict the oil flow. As long as it was winter, I figured I would pull the valve covers and take a look.
