turn signal switch 69 b body #1493917
09/01/13 12:29 PM
09/01/13 12:29 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
The cam broke on my turn signal switch. Tried another cam but it did not work so I'm going to replace the entire assembly. I've herd some talk about the new aftermarket switches having defects. Anyone know about this? Is it better to spend the extra money for NOS??
Re: turn signal switch 69 b body [Re: frank] #1493918
09/02/13 02:26 AM
09/02/13 02:26 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I used an NOS on my 68 Roadrunner. no problems... A friend with a 71 Charger bought repop fomr one of the big places, and it was trouble... he would up buying one from a place called shemar (sp) fixed his problems...
Re: turn signal switch 69 b body [Re: sthemi] #1493919
09/06/13 06:06 PM
09/06/13 06:06 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
I bought a repo for my 68 X and it lasted less than a thousand miles before it broke. One side I either have to hold the stalk to keep it on or it doesn't cancel. It didn't have a roller contact for the horn which I didn't like either. I see some of the current ones do. I just got a new woodgrain wheel and debating whether or not to try another repo or pony up for a NOS while the wheel is off. Thanks for your answer sthemi!
Re: turn signal switch 69 b body [Re: frank] #1493920
09/07/13 10:24 AM
09/07/13 10:24 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've heard of numerous issues with the repops for the 67-69 switch ( 1970 and later is still avail thru Mopar )
Fortunately I have not HAD to use a repop ,,, yet.I've done maybe 3 or 4 early columns and have been able to come up with an nos reasonably (under $100 ) every time.
Until NOS becomes impossible to find,, I have no plans to use any repop switch.
Comebacks suck and time is money
