Re: Hidraulic Cam with Solid Lifters
[Re: GTMaracucho]
#149210
11/11/08 11:30 AM
11/11/08 11:30 AM
RapidRobert
I do not think you can though you can go the other way & you'll just lose some some lift.
[Re: MoparforLife]
#149212
11/11/08 12:21 PM
11/11/08 12:21 PM
Yep, did it with a .480 comp cam and run solids on it.
At the time I was young, dumb, and dirt poor.
Car had a 318 with 1.88 intake 360 heads milled .040, M1 single plane intake and 750 Holley 3310.
I'm guessing I probably had all of 7.5:1 CR in the loose re-ringed and bearinged shortblock.
Actually, the car ran pretty good for being slapped together and would RPM past 7k easily (other than throwing a belt once in a while.)
It weighed about 3,500 with me in it and ran 14's @ 95 mph with 3.23 gears, street tires and exhaust.
So, yes, you can run a hydraulic cam with solid lifters...
[Re: 68LAR]
#149215
11/11/08 01:21 PM
11/11/08 01:21 PM
RapidRobert
wouldn't you want to set the lash at solid cam specs? I would think it'd need more for expansion the same as if you were running solid/solid.
[Re: RapidRobert]
#149218
11/11/08 03:00 PM
11/11/08 03:00 PM
Just an FYI, I set my clearance at .018 intake and exhaust.
[Re: GTMaracucho]
#149220
11/12/08 01:25 PM
11/12/08 01:25 PM
The funny part about all of this is I was talking to a retired neighbor a couple of years back about this very topic.
He had owned a small machine shop in the little town where we lived.
He had no idea that I'd done what I spoke about in the above post but started talkin' about "speed secrets" that they did back in the day.
He brought up using solid lifters on a hydraulic cam as one of the "secrets".
I just thought it was kinda funny that I had done exactly what he had brought up.
[Re: 70dart360]
#149222
11/12/08 04:42 PM
11/12/08 04:42 PM
Posts: 10,696 North Dakota
6PakBee
North Dakota
When I was a kid this was supposed to be the 'hot tip' for a 216 Chevy. You used the hydraulic cam from a Powerglide 235 and ran the 216 solid lifters on it. Cam lasted about 15 minutes. My one and only exposure to this.
