Re: Factory spade terminals (where to buy) [Re: Brian_wo] #1486518
08/19/13 11:13 PM
08/19/13 11:13 PM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
Accel, got 4 sets of interchangeable jaws, ratchets. Just looked no # but has yellow handles, well made. Can't remember exact $ but was a little pricey but sure works well!
Re: Factory spade terminals (where to buy) [Re: m88mark] #1486519
08/20/13 01:58 AM
08/20/13 01:58 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
I bought mine from the a place called the terminal repair store i bought 50 ea the male one was like $12 for 50 . i also have the crimper for these they say packard on them they are a ratcheting and do the double crimp for these terminals . i bought a nice used dash harness replaced all of the ends at the bulkhead and replaced the ends for the light and wiper harness ,
Re: Factory spade terminals (where to buy) [Re: mopwrd340] #1486520
08/20/13 09:22 AM
08/20/13 09:22 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Terminal Supply, they have everything.
I bought a kit from them for automotive applications
that was great when rewiring our Charger.
Joe
Re: Factory spade terminals (where to buy) [Re: jlatessa] #1486521
08/20/13 09:39 AM
08/20/13 09:39 AM
Alberta, Canada
K
krisiesmopes Offline
K
Alberta, Canada
The females are 2427736 and come the same way.
Re: Factory spade terminals (where to buy) [Re: 62maxwgn] #1486522
09/11/13 10:38 AM
09/11/13 10:38 AM
PA
BTTG Offline
BTTG  Offline
PA
Just to confirm before purchasing...
this tool will crimp both male and female packard 56 terminals on mopar wiring harnesses?
http://www.amazon.com/SARGENT-Tools-1028...=I23NYY2UQ7C6T0
Re: Factory spade terminals (where to buy) [Re: BTTG] #1486523
09/11/13 12:12 PM
09/11/13 12:12 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Re: Factory spade terminals (where to buy) [Re: BTTG] #1486524
09/11/13 07:37 PM
09/11/13 07:37 PM
Omaha Nebraska
Brian_wo Offline OP
Brian_wo  Offline OP
Omaha Nebraska
did you see somewhere that it works with packard 56 terminals? all the tools I found were pricey.
who is that guy?
Re: Factory spade terminals (where to buy) [Re: BTTG] #1486525
09/11/13 07:40 PM
09/11/13 07:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Looks more like it's for Stakon connectors, not P56's.
Don't be the exception.
Re: Factory spade terminals (where to buy) [Re: Brian_wo] #1486526
09/12/13 08:35 AM
09/12/13 08:35 AM
PA
BTTG Offline
BTTG  Offline
PA
Read here that it does... However the product number was NOT given by the apparently very knowledgeable poster describing the crimp process... Since it was not firsthand I did not want to assume the other poster was correct...
http://www.thegaragegazette.com/index.php?topic=2924.0
As far as I can tell the sargent one does look like it is similar to the one above posted by 62maxwgn
Again just want to confirm before spending $30... I can't afford the full duty versions which are big $$'s as i won't use often...
TIA
