Which Intercooler? #1486016
08/17/13 10:35 PM
08/17/13 10:35 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
What are the pros and cons of a good air/water intercooler?? I have available a good marine intercooler and am trying to determine if it's worth it to try to use it in a vehicle.
Re: Which Intercooler? [Re: Blucuda413] #1486017
08/17/13 11:11 PM
08/17/13 11:11 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
are you talking about under a roots intercooler?
Re: Which Intercooler? [Re: Clanton] #1486018
08/17/13 11:21 PM
08/17/13 11:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm wondering if he is talking about a heat exchanger
that is used in salt water boats... but that has the
engine water on the one side and salt water on the other...
that wont move enough air
Re: Which Intercooler? [Re: MR_P_BODY] #1486019
08/18/13 01:32 AM
08/18/13 01:32 AM
Alexandria, LA
Alexandria, LA
I talking about a Procharger unit. I believe it is a AW504. I can't find a lot of info but I assume you could plumb it into engine cooling system or a separate cool water tank. They use these with some pretty big superchargers so I doubt the air flow would be a problem. I know there are some who use the W/A systems in autos and it would appear that set up correctly it would be more efficient than an A/A system. Anyone have any experience????
Re: Which Intercooler? [Re: Blucuda413] #1486020
08/18/13 01:57 AM
08/18/13 01:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its different than the heat exchangers then... but
if they use it for a procharger in a boat then yes
you can use it in a car... if its fits(boats usually
run big stuff like that due to the space)... but I
sure would try it
Re: Which Intercooler? [Re: Blucuda413] #1486021
08/18/13 10:58 PM
08/18/13 10:58 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Strictly race car use a/w intercooler and get a water tank with a rule water pump and pack it full of ice. Street car get a/a.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Which Intercooler? [Re: 1967dartgt] #1486022
08/18/13 11:28 PM
08/18/13 11:28 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
If you have one and it will not be a restriction then it will help make power.
If your on race gas it is more necessary then alcy.
