Wanna make 440 Cuda more street then strip #1485305
08/16/13 04:10 PM
08/16/13 04:10 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
I would like to make my cuda more street friendly considering the car never makes it to the track anymore. Right now with the 3800 stall 10" vert, 28" tires and 4.10 gears I am cruising at 3,000rpm and above. I have a set of 3.55 gears that I would love to put back in the car but am wondering what I would need to change to get the combo to work.
Combo right now is '72 Cuda with .030" over 440 with eddy 84cc heads, 9.9:1 compression, 825 mighty demon, mp 509 hyd in at 102, eddy perf rpm intake, 727 w/rev man valve body, 10" TA 3800 stall vert, 4.10 gears, 28" tire.
I am thinking of switching to the voodoo 10230703 hyd cam (268/276, 226/234 @.050, .494/.513, 110 lsa, 106 icl. Rpm range on this cam is listed as 1800-6200 which is perfect. For comparison my 509 cam now is 292/292, 248/248 @.050. .509/.509 with an rpm range of 2600-6000.
Question is besides the cam, what else would I need to change to make the 3.55 gears work in my combo? Would I need to tighten up the vert? Anything else? Just looking for a fun street cruiser with plenty of torque.
'72 440 Cuda
11.673 @ 115.91 w/1.663 60'
Re: Wanna make 440 Cuda more street then strip [Re: tywebb2] #1485306
08/16/13 04:26 PM
08/16/13 04:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Changing the cam you would want to put a lower stall convertor in it , how much lower I can't really say
Re: Wanna make 440 Cuda more street then strip [Re: tywebb2] #1485307
08/16/13 04:26 PM
08/16/13 04:26 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Just put the gears in and see how it does.
Sheldon
Re: Wanna make 440 Cuda more street then strip [Re: RUNCHARGER] #1485308
08/16/13 04:49 PM
08/16/13 04:49 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
I had the 3.55 gears originally and the 509 cam did not like that. Guess I could do the cam and gear swap and see what it's like.
'72 440 Cuda
Re: Wanna make 440 Cuda more street then strip [Re: tywebb2] #1485309
08/16/13 06:40 PM
08/16/13 06:40 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I would guess 2500-3000 converter, depending on how you're gonna drive it. I'm sure someone's got a 3800-stall converter with a similar combo, but I'd want something tighter for cruising around at lower RPM. Best to ask the cam mfr.
Re: Wanna make 440 Cuda more street then strip [Re: topside] #1485310
08/16/13 07:31 PM
08/16/13 07:31 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Id swap the gears and cam first and see if you like it before swapping the converter.
Re: Wanna make 440 Cuda more street then strip [Re: AdamR] #1485311
08/16/13 07:48 PM
08/16/13 07:48 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Wanna make 440 Cuda more street then strip [Re: tywebb2] #1485312
08/16/13 10:23 PM
08/16/13 10:23 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I had a similar combo (Racer Brown .510, 906s, 3500 conv.) in my '70
Roadrunner but with 10.5 comp., the 3.55s worked great and ran 12.0s
on street BFGs.
Re: Wanna make 440 Cuda more street then strip [Re: Dan Halen] #1485313
08/16/13 10:50 PM
08/16/13 10:50 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i'm using an engle k65 solid, 238@.050-.510 lift, with an old street hemi converter and 3.23 gears (440+6 in a '65 coronet). it's got enough poop for me and drives real nice with the 3.23 and tighter converter.
