Carb question-UREMCO carbs from Summit #1485020
08/15/13 02:38 PM
08/15/13 02:38 PM
Moncton, New Brunswick
hemidart1 Offline OP
http://www.summitracing.com/parts/urm-6-694/applications/make/plymouth?prefilter=1
Would this carb work on mildly built 360(8.6 -1 , hughes cam). I am wondering if this carb is the original style for the 273 Commando. I am building a 360 to look like a 273 Commando-right down to the valve covers and correct breather. I am assuming this carb would fit an original 273 Commando air breather.
Any feedback would be great.
thanks
Al.
1967 Hemi GTX
1969 Chrysler 300
Re: Carb question-UREMCO carbs from Summit [Re: hemidart1] #1485021
08/15/13 02:51 PM
08/15/13 02:51 PM
dogdays Offline
dogdays  Offline
$300? That's a lot of bread.......
It's a Carter AFB and they basically all look the same.
I'd look at a new Edelbrock 625. Take off the Edelbrock nameplate, and you have a new carb that's also bigger than the 273 carb and more in line with a 360's needs. You may need to do a couple of things for linkage and choke.
R.
Re: Carb question-UREMCO carbs from Summit [Re: dogdays] #1485022
08/15/13 03:11 PM
08/15/13 03:11 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The carb pictured is not a Mopar carb, it looks like a Pontiac unit (fuel outlet should be on the passenger rear for a Mopar). An actual 273 single four AFB looks very unique, they also have the smaller air horn (unlike modern air horn AVS/Edelbrocks) so with a stock air cleaner you'll need a small dia air horn AFB.
Re: Carb question-UREMCO carbs from Summit [Re: ScottSmith_Harms] #1485023
08/15/13 03:21 PM
08/15/13 03:21 PM
dogdays Offline
dogdays  Offline
So, SSH, What is the largest carb that will fit under the 273's air cleaner?
How difficult is it to find a "real" 273 carb?
How much would it cost the OP to have you do such a carb?
Or the largest carb mentioned above?
I am assuming the OP wants it to "look" original, but I don't believe he's talking about looking original to a concours judge. So what's the best way to go to feed that 360 and still keep it looking like a 273 to the casual bystander?
Would it be possible to modify the stock air cleaner base to work with the later larger OD airhorns?
R.
Re: Carb question-UREMCO carbs from Summit [Re: dogdays] #1485024
08/15/13 03:57 PM
08/15/13 03:57 PM
R.
yeah -what he said
I need a carb that will fit the original air cleaner
1967 Hemi GTX
1969 Chrysler 300
Re: Carb question-UREMCO carbs from Summit [Re: dogdays] #1485025
08/15/13 04:09 PM
08/15/13 04:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
4 5/8" diameter air horn is the opening limit, the largest stock AFB's are roughly 600cfm, most are less.
Finding one might take some searching
Or the largest carb mentioned above? I will restore any customer supplied good core AFB to "like new" condition for $399.00. I can also build clones just like my Hemi clones which will have as much as 800 cfm, they are based on new style Edelbrock AVS carb bases with vintage 4 5/8" tops. This way you can still use your original air cleaner, all other stock parts fit as they should, you get a carb that looks and runs as good as a new one and uses readily available modern jets and rods. These are $599.00 plus shipping, built to order.
I am assuming the OP wants it to "look" original, but I don't believe he's talking about looking original to a concours judge. So what's the best way to go to feed that 360 and still keep it looking like a 273 to the casual bystander? The clones I mentioned above
Would it be possible to modify the stock air cleaner base to work with the later larger OD airhorns? Sure, anything can be hacked up, but I wouldn't do that to an original 273 air cleaner
Re: Carb question-UREMCO carbs from Summit [Re: hemidart1] #1485026
08/16/13 02:52 AM
08/16/13 02:52 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
4131's are plentiful. They are small tops and were designed to feed a 383 to 440. They might be kind of small on the CFM's. Maybe 500?
That carb in the ad? Read that might not look like the actual unit.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Carb question-UREMCO carbs from Summit [Re: Rug_Trucker] #1485027
08/16/13 09:25 AM
08/16/13 09:25 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You'd think they'd use the best looking example in the picture, maybe they did.
Don't be the exception.
