help me pic a cam for my 360 #1483474
08/12/13 07:30 PM
08/12/13 07:30 PM
mesa arizona
moturbopar Offline OP
mesa arizona
Hey all need to pick a cam for my 84 d150 short bed. Truck has 3.55 gears and 904 with stock converter. Plan on going to a500 with 2500 stall converter. The engine is .030 over 360. Stock style pistons sit .073 below deck (uhhggg), magnum heads 64cc, 8.9 to 1, stock valves, with a little pocket porting. air-gap intake, 600 holley, 1 5/8 long tube headers, that exit into 2.5 head pipes, then a flowmaster y that goes to a single 3". What im wondering is what cam do you think would be good for this, it has power brakes, power steering, a/c. truck will be used mostly for cruising around and hauling light things, will hardly ever tow anything, not worried about emissions either. Im looking at the comp xe262h. But what cam do you think would work well?
Re: help me pic a cam for my 360 [Re: moturbopar] #1483475
08/12/13 08:21 PM
08/12/13 08:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: help me pic a cam for my 360 [Re: 340SHORTY] #1483476
08/13/13 11:00 AM
08/13/13 11:00 AM
mesa arizona
mesa arizona
Thanks, I will give them a call. Do you all think its safe to run 1.6 ratio rockers with an aggressive lobe? I would like to keep the stock rockers until I can afford to go roller?
Re: help me pic a cam for my 360 [Re: moturbopar] #1483477
08/14/13 03:11 PM
08/14/13 03:11 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
had a nearly identical set up (save a 600 edelbrock) in my 3900 lb 5th ave, but with factory smog heads...was pretty good, had some issues with low RPM surging when lockup and OD engaged at 45mph. I'd suggest dropping to the XE256, or the similar sized lunati voodoo and use hughes #1110 springs
http://www.lunatipower.com/Product.aspx?id=2341&gid=297
oh, and the magnaflow Y's are much nicer than the flowmasters, I've used both
when I built my 318 with mag heads, I used the same hughes #1110 springs with stock rockers and Bullet Cam's HR259/316 roller cam lobe, which is as aggressive as any of the voodoo or hughes flat tappet lobes without issue
I used stock magnum keepers and 2.2L retainers with the hughes springs
2017 Grand Cherokee Overland
Re: help me pic a cam for my 360 [Re: patrick] #1483478
08/15/13 09:58 PM
08/15/13 09:58 PM
mesa arizona
mesa arizona
Thanks. I think for now I am just going to run a non lockup 904 with a 2500 converter and 3.55 gears. I think the xe262 will work fine for that. Already have the flowmaster y, or I would have probably bought the magnaflow y. SO how did your car run with your combo?
Re: help me pic a cam for my 360 [Re: moturbopar] #1483479
08/15/13 10:33 PM
08/15/13 10:33 PM
ill
dennismopar73 Offline
ill
Not on the "Hughs ' band wagon, so I would run just about any comp/racer brown cam in the 280 480/284 484 range be happy camper,
I ran a 273 h comp in my old road runner 360 , great low end, mid range cam worked very well with a 600 holey/750 dbl,street strip deal ,
my 2cents
Re: help me pic a cam for my 360 [Re: moturbopar] #1483480
08/15/13 11:14 PM
08/15/13 11:14 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
The XE262 is a nice cam. You'll have a little of both worlds. Good torque and good high RPM up say to 5,800. Get the full kit with the XE262.
I ran that same cam in my 383, so it should be real nice in your 360.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: help me pic a cam for my 360 [Re: moturbopar] #1483481
08/16/13 11:35 AM
08/16/13 11:35 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
never took it to the track, but it kept up with 1st gen hemi LX's (so I'd assume low 14's)
