Who sells an SB Water pump with anti-cavitation plate? #1482893
08/11/13 03:47 PM
08/11/13 03:47 PM
North Austin
KnuckleDuster Offline OP
North Austin
...and the age old question,six or eight vane for non-ac pulleys? What really cools better?
I know you can weld a plate on, but that requires a welder.
Re: Who sells an SB Water pump with anti-cavitation plate? [Re: KnuckleDuster] #1482894
08/11/13 04:17 PM
08/11/13 04:17 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Milodon water pumps have a anti cavitation plate welded on them.
Re: Who sells an SB Water pump with anti-cavitation plate? [Re: KnuckleDuster] #1482895
08/11/13 06:23 PM
08/11/13 06:23 PM
eight does. You might drop the pump off at a welding shop & just have them weld a round plate on the outside of the vanes (for a SB). I cut a round piece out of a washing machine panel with a saber saw then my welder did it in no time. Tell em to hold the edge of the piece flat against each of the 8 tines when they weld it 8 times & also cut a hole in the center & have him weld it there also. It'd be alot cheaper than an aftermarket one
