no kick down cable #1482644
08/11/13 01:38 AM
08/11/13 01:38 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
ok so got every thing done on the d150 project just bolt a seat in, inner fender an a few odd's an end's an she is 100% done, now I had the tranny rebuilt an I had bought a valve body from a member on here that has a tf-3 kit installed, my question is I will not be running a kick down cable do I need to wire the lever open or half way for the line pressure??? truck is a street driver an yes I know the story's about what the kind of damage it will do ect..
drive fast, drive hard, DRIVE MOPAR
Re: no kick down cable [Re: lifted85] #1482645
08/11/13 02:42 AM
08/11/13 02:42 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Wire it wide open.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: no kick down cable [Re: Prodart440] #1482646
08/11/13 03:20 AM
08/11/13 03:20 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
If the valve body is converted from an auto shift to a manual shift valve body there is no need to do anything with the lever..
I am truckless..
Re: no kick down cable [Re: 340SHORTY] #1482647
08/11/13 03:57 AM
08/11/13 03:57 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
the tf-3 kit is a manuel shift kit correct? I just wasn't sure... thanks for the info guy's
Re: no kick down cable [Re: lifted85] #1482648
08/11/13 04:11 PM
08/11/13 04:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The TF-3 can be run with or without linkage/cable, if no linkage is used wire it wide open (all the way to the rear).
