Re: 4.7 into E body?
[Re: derekeh]
#1482353
08/10/13 04:37 PM
08/10/13 04:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I haven't, wife has a 4.7 in her Ram and I've looked it over as a possible swap candidate into my 65 Cuda, oil pan issues though. Not sure if anyone makes a center sump that'll fit a pass car for these engines. I suppose if I pay someone enough they will, but I'd be more likely to try to make an adapter plate to fit a B/RB pan on first.
[Re: derekeh]
#1482354
08/11/13 11:32 AM
08/11/13 11:32 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I've looked at the 4.7 swap. It's a good engine and I really like it. However, there is little support in the aftermarket. You could swap in some HO cams and headers but that's it.
You're light years ahead by dropping in a 5.7 hemi and calling it a day. You'll end up being way ahead on power for the same fuel burned.
[Re: feets]
#1482355
08/11/13 11:33 AM
08/11/13 11:33 AM
Posts: 5,438 Michigan
oldjonny
Don't argue with me.
Why a 4.7? No support for the engine. Definitely not the way that I would even consider
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: oldjonny]
#1482356
08/11/13 11:54 AM
08/11/13 11:54 AM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
Google 4.7 engine problems and see just how good they are,of course that should also depend on the year,the pre 2001 ones had many failures.
Modern Hemi would make you much more happy.
who is that guy?
