Hemi Conversion Schumaker Mounts Air grabber? Alignmen
#147963
11/09/08 10:55 PM
11/09/08 10:55 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Have some slight alignment issues with my air grabber and hemi with schumaker mounts Then I read this in regards to new manifold " This new aluminum in-line Dual Quad Hemi Intake Manifold is based on the Marine/NASCAR version and is built from the original tooling. Machined to accept aftermarket AFB or Holley carburetors (P4452778 rear, P4452779 front — see Fuel Systems section of this catalog). Will fi t production 426 Hemi heads and has provisions for manifold heat and power brakes. It retains the stock height of the production 1966–71 Street Hemi AFB intake manifold. Production AFB air cleaner baseplate/lid will need to be changed or modifi ed. Some O.E. and aftermarket linkage components and fuel lines are needed to complete the installation. Am I the only one ?? Disregard the manifold , I guess it only applies to marine manifolds ..
Re: new hemi intk maniflds , Air grabber alignment 71 bbody
[Re: sogtx]
#147964
11/10/08 01:45 AM
11/10/08 01:45 AM
Posts: 10,124 A Red State
SNK-EYZ
A Red State
What are the alignment issues you're having?
The marine intakes carb spacing (center to center) is wider compared to the production street Hemi intake.
But it's my understanding that was the only difference.
[Re: RUNCHARGER]
#147969
11/10/08 08:27 PM
11/10/08 08:27 PM
sogtx
upstate western ny
As I stated before - i goofed I dont have a marine manifold, i just read the wrong description in a sales ad for street manifolds . Thought tehy might all require mods to baseplate .. Do the Schumakers shift the engine left or right ? Or just up ?
[Re: sogtx]
#147970
11/10/08 10:04 PM
11/10/08 10:04 PM
sogtx
upstate western ny
I just got back in and checking left and right backwards and forward ,, The fan does not seem to be exactly EVEn in the shroud .. The driver side of engine seems to sit up higher The wingnuts of my lid are not on center of my air grabber .. Are the air boxes offset ? It doesn't seem so .. Any one else ..
[Re: sogtx]
#147971
11/10/08 10:13 PM
11/10/08 10:13 PM
sogtx
upstate western ny
Just read this from a post in 2006
" i dropped a hemi in a 72 Road Runner with a A/grabber hood. parts i used. mopar performance siamese hemi block, old style stage 5 hemi heads without a bolt hole for the alternator. indy 16 bolt single plane intake modified by milling 1/2" of the top. mopar performance valve covers, TTI big tube headers repo bower brake booster and bracket of un-known manufacturer, big bolck fluid dampner, stock 400 pulleys, flex tube dip stick, mopar performance mini starter, shumacher conversion mounts on a 400 K member. with the shumacher mounts the motor sits a bit to the passenger side and a bit higher than stock. the valve covers clear the right shock tower but the rub when i stand on it. DON'T buy the big tube TTI headers. they aren't worth the headaches on a street car. i have a buddy who has a 71 charger with the A/C mounted in the stock location. he had to modify the A/G base to get it to fit but it fits now. i am not sure how it would fit with a shaker aircleaner. he clears the A/C blower motor motor with cast valve covers also without mods. all i can say is PLAN in advance and go to the big shows and look for builds like you plan to do and ask alot of questions to the people who have done it before, nothing beats seeing instalations first hand instead of looking at pics. "
I dont know how many hours I have into this BS
I know, I must have a deviated hemi block ... just like we cant fit a keisler in an aar ..
For Trade One 71 GTX with a crooked hemi for a 2009 challenger ..
Re: Hemi Conversion Schumaker Mounts Air grabber? Alignmen
[Re: sogtx]
#147975
11/11/08 09:44 AM
11/11/08 09:44 AM
Posts: 74,937 U.S.S.A.
JohnRR
U.S.S.A.
I would assume that any shim would only raise the engine higher ..
yep .
contact megaparts , order a repop K and the CORRECT engine brackets , there ARE differences and you're done .
[Re: JohnRR]
#147976
11/11/08 10:48 PM
11/11/08 10:48 PM
sogtx
upstate western ny
That would be the correct way .. Schumaker said theyd fix anything as necessary .. quite a gentleman tech support was good .. Arruza said 25 years not one complaint .. Hemi kframe is $ 435 dollars difference + shipping .. I gotta try Arruzas first ..
[Re: sogtx]
#147977
11/11/08 11:42 PM
11/11/08 11:42 PM
JohnRR
U.S.S.A.
you built a F.A.S. T . LEGAL HEMI and you are crying over 435 bucks
sorry but thats
do it ONCE , do it RIGHT ... but that's just me
[Re: JohnRR]
#147979
11/12/08 01:24 AM
11/12/08 01:24 AM
Posts: 18,157 Mass
DAYCLONA
Mass
The first problem is probably the schumacher monuts , when you have to deal with alignment to underhood ductwork you really need to go with original parts or accurate reproductions .
When I did the G-Series 71 wingcars, all 3 used 472 crate Hemis using shumacher conversion mounts on the B/RB K frame (which I assume Andy is using?)...running factory airgrabber hoods Dodge/Plymouth......along with my custom Hemi 6Pak cast Aluminum intakes, using Mopar Performance stock aircleaners, and factory airboxes.....everything lined up fine, and that was even throwing in a custom manifold......only install problem was TTI headers.....I don't think the Shumacher mounts are the issuse
[Re: sogtx]
#147980
11/12/08 01:26 AM
11/12/08 01:26 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: sogtx]
#147981
11/12/08 01:27 AM
11/12/08 01:27 AM
Posts: 18,157 Mass
DAYCLONA
Mass
