440 oil pan #1478596
08/02/13 08:56 PM
08/02/13 08:56 PM
Stouffville Ontario
7434 mopars Offline OP
Stouffville Ontario
My 70 Challenger 440-6 has an oil leak
I want to reseal the pan and timing cover
can someone tell if there will be enough clearance between the
K frame once the steering linkage is removed ?
Re: 440 oil pan [Re: 7434 mopars] #1478597
08/02/13 09:21 PM
08/02/13 09:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
More than likely you will need to lift the engine...
I am truckless..
Re: 440 oil pan [Re: 340SHORTY] #1478598
08/02/13 11:16 PM
08/02/13 11:16 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Not really,there is only about 2" of the pan above the K frame.
Re: 440 oil pan [Re: 7434 mopars] #1478599
08/02/13 11:30 PM
08/02/13 11:30 PM
No problems on the RB, B and 426 Hemi motors in the E and B bodys to remove the oil pan and timing covers once the steering crossbar is out of the way Done that a lot more than once
Re: 440 oil pan [Re: Cab_Burge] #1478600
08/02/13 11:44 PM
08/02/13 11:44 PM
Stouffville Ontario
Stouffville Ontario
Thanks for the info fellows
makes it easier when somebody has done it
