EBody Wiring Question #1477861
08/01/13 06:45 PM
08/01/13 06:45 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
Trying to get the reverse gear (manual trans) indicator to work on my 70 Chall. Checked switch on trans works fine. Harness from switch goes to bulkhead connection and has a Black/white tracer wire with a female slip connector coming form it on the engine side. Inside I have the light with a single orange wire. I replaced the harness during the resto with a YO for 4 spd. Can anyone tell me how AI can get this to work? (This is a 4 spd conversion)
Re: EBody Wiring Question [Re: 70VERT] #1477862
08/01/13 10:25 PM
08/01/13 10:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The trans switch is the ground for the light, The 12v source comes from a connection under the dash,
SO,
test #1 if you have 12v at the light connector with the key on, (think test light) step one is complete.
If not you now know why the light isn't working.
if you do,
that would indicate You either have a connection issue between the trans and light (IE: ground) or the trans switch is not working. If you jumper the output wire at the trans pigtail to ground and the light works the trans switch is bad or the linkage is misadjusted not allowing the internal lever to fully activate the switch,
Re: EBody Wiring Question [Re: TJP] #1477863
08/01/13 10:53 PM
08/01/13 10:53 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
I checked the trans switch and it is working. Also there is a 12 v xource at the light. how do I wire from the switch to the light? The harness is now hooked to the bulkhead connector and I can't find where it comes out under the dash
Re: EBody Wiring Question [Re: 70VERT] #1477864
08/02/13 01:16 AM
08/02/13 01:16 AM
kansas city, mo
rave_12000 Offline
rave_12000  Offline
kansas city, mo
search archives. there are bunches of wire diagrams. mamopar site?
Re: EBody Wiring Question [Re: rave_12000] #1477865
08/02/13 09:14 AM
08/02/13 09:14 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
from manual
Re: EBody Wiring Question [Re: 71_deputy] #1477866
08/02/13 11:53 AM
08/02/13 11:53 AM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
HELp,I'm struggling here.... I have one orange wire coming from the reverse lamp and the socket is grounded to the dash. The two wires from the trans switch go to the bulkhead connector and there is one wire with a grey female slip on connector coming from the connector on the engine side. On the other side of the bulkhead conn, all I can see are 2 white wires exiting and one looks like it goes to the brake switch I don't see how this can work electrically. I'm a body man that operates heavy equipment so bear with me guys
Re: EBody Wiring Question [Re: 70VERT] #1477867
08/03/13 12:27 AM
08/03/13 12:27 AM
IMGTX Offline
IMGTX  Offline
Positive voltage flows from the fuse block to pin 8 on the bulkhead connector through the reverse light switch and back through pin 7 on the bulkhead connector and eventually out to the reverse lamp in the taillights.
If you look at the diagram 71 deputy posted you will see that the Positive voltage is sent to the dash lamp from pin 7 on the bulkhead connector.
You need to find the connector that comes from pin 7 on the bulkhead connector. It is on the engine compartment side of the bulkhead. IF you have the correct dash light then it will have a long pigtail with a grommet on it.
Notice this thread.
https://board.moparts.org/ubbthreads/showflat.php?Number=4995146
I do not have my 4 speed car close or I would track it down myself to show you. Sorry about that.
Hope it helps
Re: EBody Wiring Question [Re: IMGTX] #1477868
08/03/13 12:50 PM
08/03/13 12:50 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
Thanx! Think I have it now
