Page 5 of 5 1 2 3 4 5
Re: 383 starter size problem [Re: JohnRR] #1476962
08/22/13 03:20 PM
08/22/13 03:20 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Re: 383 starter size problem [Re: pushbutton] #1476963
08/22/13 06:30 PM
08/22/13 06:30 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
Re: 383 starter size problem [Re: superbeedave] #1476964
08/23/13 05:42 PM
08/23/13 05:42 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Re: 383 starter size problem [Re: pushbutton] #1476965
08/26/13 10:24 AM
08/26/13 10:24 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Any progress?
Re: 383 starter size problem [Re: pushbutton] #1476966
08/26/13 08:10 PM
08/26/13 08:10 PM
Nashville, TN
MOPARMIKE69 Offline OP
Nashville, TN
Sorry to leave everyone hanging but I have been on a 5 day raft trip shooting the rapids in the bottom of the Grand Canyon. No internet , phones, or electricity. AWESOME trip!
Anyway back in the Hotel in Vegas.
Pulled transmission and took it into the shop the last day I was in town. Really have no idea where to go now. Pulled the 513 bell and there were dowels in place. So
Starter stock and matches other original starter. Flywheel, 130 tooth, 13 1/4 diameter. Bell housing, 513, alum. What the #$%!.
Guess I am going to replace the bell since the two bottom trans mounting holes were stripped and I had to heli coil it. Then going to try to borrow from someone in the club another flywheel and test fit it with the starter. Not sure what else to do?
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 383 starter size problem [Re: MOPARMIKE69] #1476967
08/26/13 09:26 PM
08/26/13 09:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Nothing wrong with helicoils if installed properly , but if you want to waste money getting another bell you are definitely going to have to dial it in so you may as well get some practice doing the one you have.
The 13.25 number , flywheel itself or does that include the starter ring gear teeth ?
Re: 383 starter size problem [Re: JohnRR] #1476968
08/27/13 12:01 PM
08/27/13 12:01 PM
Nashville, TN
Nashville, TN
Tip of tooth to tip of tooth
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: 383 starter size problem [Re: MOPARMIKE69] #1476969
08/27/13 01:11 PM
08/27/13 01:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If I can remember I'll dig out a 130 tooth wheel tonight and measure it.
Re: 383 starter size problem [Re: JohnRR] #1476970
08/29/13 12:14 AM
08/29/13 12:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mike I have a Mcleod billet 6 bolt steel wheel , it measures roughly 13 5/16 across the teeth. I have yet to install it on anything so I can only ASSuME it's correct.
Re: 383 starter size problem [Re: JohnRR] #1476971
09/03/13 09:55 AM
09/03/13 09:55 AM
Nashville, TN
Nashville, TN
Final results:
Club member has 70 dodge super bee 383 car with 4 speed. All original parts. Took flywheel, bell housing and starter to his house.
Flywheel exact match.
Bell housing - exact match, even the same date code.
Starter - exact match
So what gives???????
Dowel pins. Both looked like off sets. Pulled them, put in stock straight ones.
Got out the dial indicator. It is well within tolerance. Bolted up the flywheel and put the bell on. Starter fits!
BUT! there isn't an imput shaft bushing in the crank!
Ordered one.
Transmission was "rebuilt" BUT none of the seals were replaced. So had it completely gone through by a local Mopar knowledgable shop.
So thanks to all who helped on this thread and special thanks to Wayne Brewer.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
