aftermarket 6 pak jet sizes #1476645
07/30/13 10:00 PM
07/30/13 10:00 PM
Milwaukee
P
poppa Offline OP
poppa  Offline OP
P
Milwaukee
What are they?? All posts I have seen say around a 66 for the center but for the outboards they differ greatly. Some are saying to start with 78-80. Car is a 440 4-speed ,I have no info on the engine. This was suppose to go on a stroker but ,every time I get close to building it something else sucks up my cash. This is an all mechanical set of carbs. I was also going to start with a 6.5 power valve and a 28 squirter in the center and 31's on the outs. Thanks
Matco tools,guaranteed for a lifetime. Just not a human lifetime.
Re: aftermarket 6 pak jet sizes [Re: poppa] #1476646
07/30/13 10:41 PM
07/30/13 10:41 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if those carbs are the aftermarket mechanicals use 81's in the end carbs and 64's in the center to begin with.
Re: aftermarket 6 pak jet sizes [Re: lewtot184] #1476647
08/02/13 02:16 PM
08/02/13 02:16 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Mine run best 78/65/80 on a 440. front to back
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: aftermarket 6 pak jet sizes [Re: poppa] #1476648
08/02/13 05:16 PM
08/02/13 05:16 PM
I would start with 31 squirters in the center carb. and 25 or 28 in the outboards It is easy to flood the motor with to much suquirter when hitting all three at once
Re: aftermarket 6 pak jet sizes [Re: poppa] #1476649
08/02/13 07:22 PM
08/02/13 07:22 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if your running any kind of cam i would rethink that power valve. at the very least have a 4.5 and 5 handy if you're running rich. won't know for sure until you can pull a vacuum reading but.......
Re: aftermarket 6 pak jet sizes [Re: mikemee1331] #1476650
08/02/13 08:12 PM
08/02/13 08:12 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
According to holley site the 4782/83 call for # 31 squirt and 64 jet center is 355cfm, outer show # 28 squirt & 82 jet 500cfm . I have a set I'm going to try on a sb but last person jetted the outside way down to 72 I think I will go 75 on the outside short and 76 on the long drop side of the manifold.
Re: aftermarket 6 pak jet sizes [Re: ademon] #1476651
08/02/13 08:30 PM
08/02/13 08:30 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Best I've found is #81=.093 passenger,# 83=.094 driver but they are actually the same,#65 center, standard squirter,but there is no one size fits all !
Re: aftermarket 6 pak jet sizes [Re: 62maxwgn] #1476652
08/02/13 09:00 PM
08/02/13 09:00 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the end carbs came from the factory with either 81's or 80's, it's been a few years since i had a set. easy to tune, but linkage has to be fabbed. i don't like big squirters. i'd use .028's with tubes in the end carbs with the white 218 pump cam and a .025 with tubes and a white 218 pump cam in the center
