Torsion Bar removal tool?
#1473435
07/24/13 07:25 PM
07/24/13 07:25 PM
Posts: 903 Oregon
rtplumcrazy1
do they sell a special tool to remove torsion bars, I believe I have seen something for this procedure for sale somewhere. Can you help point me in the right direction
Put a big block 4 speed Scat Pack Dodge in your garage.
Re: Torsion Bar removal tool?
[Re: rtplumcrazy1]
#1473437
07/24/13 07:34 PM
07/24/13 07:34 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
if you are going to junk the old ones just clamp a vice-grip on there and wail it - works but damages the bar. otherwise a clamp-type tool is available, I think I gave mine to mperry after I used it years ago. Many here have made good tools for this tho.
Ride eternal, shiny and chrome
[Re: MPerry]
#1473441
07/24/13 08:02 PM
07/24/13 08:02 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Yep still have it and it has come in handy quite a few times.
I didn't expect you to give it to me so if you need it back let me know.
If it is good for squishing spiders, can I borrow it next?
(PS as for torsion bars, I never needed a tool either, just moved the control arm back enough to get the bar to move, then just slide it out by hand the rest of the way)
[Re: OzHemi]
#1473442
07/24/13 08:12 PM
07/24/13 08:12 PM
Posts: 11,657 Fitchburg,Massachusetts
MPerry
Mopahts memba'
Mopahts memba'
I don't think you could get close enough to use it with any accuracy.
[Re: RUNCHARGER]
#1473443
07/24/13 08:18 PM
07/24/13 08:18 PM
Posts: 6,516 Santa Cruz, California
Lefty
Loosen the adjuster nut, loosen the lca nut but leave it on by about 5 threads. Then use a pry bar to move the LCA and therefore the TB back. Then tap the LCA off the TB and she's out.
Sheldon
X2^ Very easy, no tool needed.
[Re: Lefty]
#1473444
07/24/13 08:29 PM
07/24/13 08:29 PM
Posts: 12,020 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
In case moving the lower control arm back doesn't get it, you can use a couple of 1" wire rope clamps tightened back to back on the 'bar. Then you can bang on them and not hurt the 'bar.
Master, again and still
[Re: johnscudashop]
#1473451
07/25/13 08:54 AM
07/25/13 08:54 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I have been making them for years. They are made from 1"X 1" steel with a knurled handle. .The tool uses 4 contact points to clamp on the bar (the factory tool only has 3. Also the tool has 2 3/8 grade 8 bolts instead of the factory 1/4 inch bolts. I have them available here http://www.custommachinecomponents.com/shopdisplayproducts.asp?page=3&id=8
I'm going to simply say this. Your tool worked for me when all the DIY Mickey Mouse methods were just a waste of time. My T-bars were IN THERE!! Nice product. Thanks.
BTW, I learned something when using this tool. You really, REALLY (!!!) to need to crank down on the bolts to way beyond the tightness you think you need. Those GR 8's can take it. Then it works like a charm with the handy old BFH.
[Re: AndyF]
#1473453
07/25/13 12:49 PM
07/25/13 12:49 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
I also have one of those factory Miller Special Tools, torsion bar removal tool. It's a heavy duty, well manufactured tool, for the removal of some really stuck torsion bars. Without that tool i wouldn't have been able to get some bars out of cars, that i had to work on at the shop, or wrecking yards. Yes, sometimes the home made, Mickey mouse, tool may work for you, but in a lot of instances they won't. And by the way, the Miller tool uses big,1/2 diameter bolts, and not 1/4 inch, like one other poster wrote about, for his tool. Have no idea where he came up with that kind of measurement. Mine has been beat on many times, to get stuck bars out out their mounts.
RF-4C Phantom 69-370 Zweibrucken, Germany
