#14719 - 03/08/05 09:41 PM update, 46 dodge pu on a dakota chassis
Mopar Ron Offline
Loc: Escondido, CA. Ron Podsiadly,...
not to much to report on my friends truck but now he has the body mounted and has the column hooked up and he is working in fitting the bed. here are a few more pics. Ron...
#14720 - 03/08/05 10:28 PM Re: update, 46 dodge pu on a dakota chassis [Re: Mopar Ron]
65rbdodge Offline
Loc: n.e. pa.
thats a cool truck! what is it getting for a motor?
#14721 - 03/08/05 10:34 PM Re: update, 46 dodge pu on a dakota chassis [Re: 65rbdodge]
Mopar Ron Offline
he is using the whole 94 dakota chassis with the 5.2 and overdrive trans. Ron...
#14722 - 03/12/05 01:01 AM Re: update, 46 dodge pu on a dakota chassis [Re: Mopar Ron]
DanMcG Offline
Loc: Central, NY
Looks good Ron....With that low stance, will the front wheels turn without hitting the fenders?
And are those custom hinge pins I see?
#14723 - 03/12/05 10:07 AM Re: update, 46 dodge pu on a dakota chassis [Re: DanMcG]
Mopar Ron Offline
Hey Dan, it looks like it will turn ok, he is going to air bag it, the stock dakota wheels go in quite a bit.
he hasn't started on the bed yet, he has cut the sides off the dakota bed and left the floor and the bed mounting in tact, then he is going to trim the floor till the step side bed sides fit and then he is going to weld the bed sides to the dakota floor.
here are a few more pics that he sent me last night, he put the power brake peddle and booster in and even the brake lines lined up and check out how nice the peddle runs around the stock dakota column. Ron...
#14724 - 03/12/05 10:13 AM Re: update, 46 dodge pu on a dakota chassis [Re: Mopar Ron]
AZ-Nick Offline
Loc: Lower AZ
Hey Ron, that garage looks familar?
71 GTX 4sp Dana GY9 HD Road King
#14725 - 03/12/05 10:17 AM Re: update, 46 dodge pu on a dakota chassis [Re: AZ-Nick]
tilt Offline
Loc: St.Clair Shores MI.
That's COOL...a true hot rodder!!
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!) 03 Mach1
#14726 - 03/12/05 10:19 AM Re: update, 46 dodge pu on a dakota chassis [Re: AZ-Nick]
KatFysh Offline
Loc: Falconer, NY
Very cool idea. I like how "simple" it looks to go together, even though I'm sure it's not.. My dad has a '53 5 window Dodge truck. It is sitting on a rotted frame..I would like to do the same to that.. Or similar..
When you decide to quit, THAT is the moment when you would've succeeded..
#14727 - 03/12/05 11:51 AM Re: update, 46 dodge pu on a dakota chassis [Re: Mopar Ron]
CrAzYMoPaRGuY Offline
Loc: Canada
Wow, sure looks like an awesome matchup!!!!!
CrAzYMoPaRGuY
#14728 - 03/12/05 12:20 PM Re: update, 46 dodge pu on a dakota chassis [Re: CrAzYMoPaRGuY]
thats awesome.
#14729 - 03/12/05 12:23 PM Re: update, 46 dodge pu on a Dakota chassis [Re: Mopar Ron]
DanMcG Offline
Loc: Central, NY
Thanks for the Pics Ron....the column and pedals look great...Is he going to keep the bug eye head lights?...I need to find fold away headlights or something other then those things....but my truck is on the end of the to do list
what will the radiator be?
#14730 - 03/12/05 12:35 PM Re: update, 46 dodge pu on a Dakota chassis [Re: DanMcG]
Mopar Ron Offline
I am going up to his house today and will get some more pics and info on how its going.
Dan I am not sure what he is going to use for radiator but I will find out.
he had to move the engine and trans back 8" and he had to put a U joint in the steering shaft but everything else is falling into place. Ron...
#14731 - 03/13/05 10:14 PM Re: update, 46 dodge pu on a dakota chassis [Re: Mopar Ron]
Hey Ron!
You should see my buddies Tow Truck! (BTW His name is Ron too. )
It's a '47 Cab and front fenders etc., a '53 Long box on an '80 1 ton Dodge truck frame.
I've got pics on here somewhere.
#14732 - 03/13/05 10:20 PM Re: update, 46 dodge pu on a dakota chassis
Just Cameron Offline
Loc: Santa Rosa, NOR*CAL.
Nice! I like the stepside next to it, too! Good work!
"When applied at precisely the right time ignorance in a powerful tool. Usually surpassing even knowledge." EJ "Michigan Madman" Potter
VP At Large, MPM C/C.
#14733 - 03/15/05 09:23 PM Re: update, 46 dodge pu on a dakota chassis [Re: Just Cameron]
Mopar Ron Offline
here is a shot of his other truck.
and the front shot of the 46 and the steering U joint. Ron...
25,638 Registered Members
195,755 Topics
72 Cuda rear seat belts
by cdstl
12/18/18 05:50 PM
R.I.P. Penny Marshall
by theraif
12/18/18 05:11 PM
Inside the hidden world of Michael Schumacher
by theraif
12/18/18 05:05 PM
1962 Plymouth crew cab $2500 .. cedar Rapids Iowa
by bigdad
12/18/18 03:37 PM
