pt cruiser trans question #1468412
07/15/13 06:56 PM
07/15/13 06:56 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
have a 2002 cruiser.It has a check engine code p07oo trans code. THe cruiser will run and drive in second gear but will not shift. It has reverse if you put it in reverse.anyone else ever have this problem?
thanks Gene
Re: pt cruiser trans question [Re: 3wracing] #1468413
07/15/13 07:33 PM
07/15/13 07:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Disconnect the battery for a few minutes and reconnect it and try driving it. You are in what is called limp mode. Po700 is a generic trans code. To get the real fault code you need to take it to a trans shop and have them read it. Most will do it for free.
Re: pt cruiser trans question [Re: 3wracing] #1468414
07/15/13 07:49 PM
07/15/13 07:49 PM
North
Dodgenu Offline
Dodgenu  Offline
North
thanks Gene
Is the speedo working? If so you
more than likely you have a bad transmission control module. It is located on the left fender under the hood.. Disconnect the wire harness from the computer and check for corrosion. Water can get past the connector and damage computer.I have done a few of those.
Re: pt cruiser trans question [Re: Dodgenu] #1468415
07/15/13 08:11 PM
07/15/13 08:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
There is alot of different trans problems that can cause the limp in which is second gear and reverse. Get it scanned to see just what the code is and then you diagnose that code. Once I scann them and get the code I like to see if its electrical or a mechanical problem or an internal trans problem. But its best to have it scanned and see just what code it set. Ron
Re: pt cruiser trans question [Re: 383man] #1468416
07/15/13 10:27 PM
07/15/13 10:27 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
prob. input or output speed sensor
