Re: Hemi distributor #
[Re: ScottSmith_Harms]
#146790
11/07/08 12:28 PM
11/07/08 12:28 PM
Posts: 10,666 North Dakota
6PakBee
North Dakota
I think he's looking at Galen's white book. It lists a:
'SPECIAL ORDER PARTS 2875255/ "LESS CAP & ROTOR" 2875327/ IBB-4401A 1968 426 HEMI BOTH (manual and automatic) A (body) TACH DR'
I've tried to accurately reproduce the listing but the original is a little jumbled.
[Re: HemiGreg]
#146792
11/07/08 01:37 PM
11/07/08 01:37 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
Its prob a tach drive "race'" unit very common and cheap
the one he is asking about isn't cheap though
[Re: JohnRR]
#146793
11/07/08 02:42 PM
11/07/08 02:42 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
If you can fund the transistor ignition control that goes with it they work real well,if not still works good.
[Re: 62maxwgn]
#146798
11/08/08 12:37 PM
11/08/08 12:37 PM
Posts: 1,131 Kent, WA
triple_green
Kent, WA
So was the hemi distributor the same as the rest of the big blocks?
I've got the one that supposedly came with my 69 hemi...but I was told it was probably not unique from other big block distributors.
Thanks!
68 Charger, 383 HP console auto, spring green, stock restoration
[Re: triple_green]
#146799
11/08/08 03:26 PM
11/08/08 03:26 PM
62maxwgn
Blair County,PA
Thanks!
Actually,the only thing that makes it unique is the tag."If it is the original tag"
[Re: 62maxwgn]
#146800
11/08/08 03:38 PM
11/08/08 03:38 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
The vacuum advance unit and the centrifugal advance are both different and have unique stamped numbers on them.
[Re: Snoopy]
#146801
11/08/08 03:59 PM
11/08/08 03:59 PM
62maxwgn
Blair County,PA
But,thats easy to change.
Original 70 Hemi on left,69 1/2 on right.
[Re: 62maxwgn]
#146805
11/08/08 09:27 PM
11/08/08 09:27 PM
triple_green
Kent, WA
what does the tag say on it?
