Page 1 of 5 1 2 3 4 5
World VS INDY alum blocks #146623
11/06/08 11:01 PM
11/06/08 11:01 PM
Tampa Fl
K
kens avenger Offline OP
mopar addict
mopar addict
K
Tampa Fl
Whats your thoughts on the two??? Quality-Strenth- weekness...have a world block here now (AJ's Bonefish) and I have Indy stuff... I been knocking Indy
.. but after looking at this one and whats happing at KB..think I will stick with Indy
Don't get me wrong its MY OPINION and you know what that gets me in here.. The world block looks nice but the Indy looks stronger to me..Wes put some pic's up of the Indy Block you just got..
one more Thing Mike at... Chenoweth... Very nice.. Finish Hone work bore to skirt is dead on.. need to call you to find out more what was done to this thing
look at the oil pan gasket form my Indy to the world block.
Remember in here some don't think you should have a Opinion.. sad fact..
Re: World VS INDY alum blocks [Re: kens avenger] #146624
11/06/08 11:02 PM
11/06/08 11:02 PM
Tampa Fl
K
mopar addict
mopar addict
K
Tampa Fl
#2
Re: World VS INDY alum blocks [Re: kens avenger] #146625
11/06/08 11:06 PM
11/06/08 11:06 PM
Tampa Fl
K
mopar addict
mopar addict
K
Tampa Fl
#3
Re: World VS INDY alum blocks [Re: kens avenger] #146626
11/06/08 11:12 PM
11/06/08 11:12 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Well, all else being equal as far as strength and rigidity, if the oil pan rails becomes the limiting factor as far as stroke, I would stay with the Indy block, if you are planning big cubes.
[image][/image]
Re: World VS INDY alum blocks [Re: sgcuda] #146627
11/06/08 11:13 PM
11/06/08 11:13 PM
sgcuda Offline
sgcuda  Offline
Now that I see your 3rd pic, doesn't the Indy block have higher webbing in the cam valley?
[image][/image]
Re: World VS INDY alum blocks [Re: kens avenger] #146628
11/06/08 11:14 PM
11/06/08 11:14 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I just picked up an Indymaxx block through Bob George. Beautiful stuff...
Re: World VS INDY alum blocks [Re: PolyDart] #146629
11/06/08 11:23 PM
11/06/08 11:23 PM
Tampa Fl
K
mopar addict
mopar addict
K
Tampa Fl
see look at the mains in the indy .. alot more meat.. mine have been cnc'ed out for the dry sump to the outer holes on the oil pan rail.. thats the first look i've had at one thats not cnc'ed.. and yes the ribs are bigger in the indy.. thanks for the INDY pic's ab7fh
Re: World VS INDY alum blocks [Re: kens avenger] #146630
11/06/08 11:31 PM
11/06/08 11:31 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Here is a few pics. I give the strength to the Indy block, I have had no issues with it.
Cast Iron World Hemi block shot
Re: World VS INDY alum blocks [Re: Bob_Coomer] #146631
11/06/08 11:34 PM
11/06/08 11:34 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Few more
Re: World VS INDY alum blocks [Re: Bob_Coomer] #146632
11/06/08 11:36 PM
11/06/08 11:36 PM
Tampa Fl
K
mopar addict
mopar addict
K
Tampa Fl
I need to look around if i have a pick of the cnc work on mine they take out a lot.. i weighed mine it was 128Lbs after the cnc work. Like i said looking at the 2 you can see how much stronger the Indy is..but thats just looks
Re: World VS INDY alum blocks [Re: Bob_Coomer] #146633
11/06/08 11:38 PM
11/06/08 11:38 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Last One
Re: World VS INDY alum blocks [Re: kens avenger] #146634
11/06/08 11:42 PM
11/06/08 11:42 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Yea
This World Hemi Block is porky..Damn thing weighed 338 LBS, thats with NO freeze or galley plugs...I think I blowed a O-Ring out moving it around..
Re: World VS INDY alum blocks [Re: kens avenger] #146635
11/07/08 01:27 AM
11/07/08 01:27 AM
iowa
wesw Offline
wesw  Offline
iowa
pete sent me some pictures of my indy block today. its time to order more parts now.
598 ci predator
Re: World VS INDY alum blocks [Re: wesw] #146636
11/07/08 01:28 AM
11/07/08 01:28 AM
iowa
wesw Offline
wesw  Offline
iowa
#2
598 ci predator
Re: World VS INDY alum blocks [Re: wesw] #146637
11/07/08 01:29 AM
11/07/08 01:29 AM
iowa
wesw Offline
wesw  Offline
iowa
#3
598 ci predator
Re: World VS INDY alum blocks [Re: wesw] #146638
11/07/08 01:30 AM
11/07/08 01:30 AM
iowa
wesw Offline
wesw  Offline
iowa
#4
598 ci predator
Re: World VS INDY alum blocks [Re: wesw] #146639
11/07/08 01:32 AM
11/07/08 01:32 AM
iowa
wesw Offline
wesw  Offline
iowa
#5 last one
598 ci predator
Re: World VS INDY alum blocks [Re: wesw] #146640
11/07/08 09:36 AM
11/07/08 09:36 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I think first thing is to compare the world race block to the indy block. Although it doesn't change much in the strength factor it has some better options like bushed lifter bores and dual bell housing bolt patterns. Indy has a larger skirt and the fifth main is cross bolted.
Some peoples opinion may be the indy block is stronger but unless you were in the design room it's only speculation. Looks can be deceiving. Something like the quality of the block material can throw that theory out the window
Most will never run either block close to their limits
Re: World VS INDY alum blocks [Re: The Shadow] #146641
11/07/08 10:37 AM
11/07/08 10:37 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There are allways going to be people who make negative speculations.I'am going to go on record to say that Indy provides a quality block.How do I know?My comment is based on facts.What facts?I use Indy blocks in our own race cars and provide them for my customers race cars as well as to other engine builders and racers.We have never had any problems with any that we provide.There are quite a few here on mopars that have Indy blocks provided by us and have been quite satisfied.No speculation here just facts.
Post deleted by Defbob [Re: B G Racing] #146642
11/07/08 10:55 AM
11/07/08 10:55 AM
