Dead rich, nothing helps. Fixed
#1464122
07/07/13 06:15 PM
07/07/13 06:15 PM
Posts: 273 FL
74-440Charger
FL
Trouble is with a Holley 4150 HP 750 cfm w/vac 2nds on a mild 440. Motor has been sitting for about a year, I replaced the plugs and wires, power valve, needle and seat assemblies, checked float levels and verified spark. Plugs are black as coal and doesn't want to idle. Ideas would be greatly appreciated. Everyone who said power valve raise your hand . I pulled it apart again to swap in another power valve, noticed a piece of gasket left from the old PV and it wasn't as tight as it could be. I stripped it al down and soaked in a new can of chem-dip and put it all together cleaner and more carefully this time. Fired right up, idle fell right in place and tweaked the timing right in. You folks are the best
Re: Dead rich, nothing helps
[Re: RobX4406]
#1464124
07/07/13 06:22 PM
07/07/13 06:22 PM
Posts: 273 FL
74-440Charger
FL
[Re: 74-440Charger]
#1464128
07/07/13 07:34 PM
07/07/13 07:34 PM
RapidRobert
It ran OK a year ago when it was parked with no changes since then. I'm assuming the fuel psi ain't too high & the PV ain't blown. What's your idle speed? It's showing 30 initial? On ported or manifold vacuum? I'd want the initial at ~15. Find out what's wonky with the timing reading. Holler back when you can
[Re: topside]
#1464131
07/07/13 07:56 PM
07/07/13 07:56 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
It sure seems that it is a power valve problem to me. I used to do mobile service calls and had one in the SeaTac Airpot parking garage with a Rambler V-8 and a Holley. I was able to get the family home by plugging the blown PV with JB weld with the advise that they could only use part throttle to get them home (85 miles)and then have the PV replaced by their local mechanic. I would try a PV plug and see if that cleans up the idle. Couldn't hurt to try.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 74-440Charger]
#1464133
07/07/13 10:12 PM
07/07/13 10:12 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
could be the coil, or MSD rusted inside. sure sounds like a bad power valve did you get the gasket in tight?? got another to try. I've seen the block to main body gaskets do the rich thing too. Do you have a good running carb to borrow and swap on. Do you still run the ballast resistor if so run a double male spade to join the wires. you put fresh fuel in?
[Re: 74-440Charger]
#1464134
07/07/13 10:15 PM
07/07/13 10:15 PM
Dodgem
Ontario, Canada
I once bought a 3 barrel they said many different carb experts looked at and it runs pig rich.
so i paid 80 buck for it telling my buddy I was sure it was the power valve.
And it was piece of gasket material stuck in it.
problem solved ran good sold it a couple years later for $150.
wish I still had it to play with.
[Re: 74-440Charger]
#1464136
07/07/13 10:43 PM
07/07/13 10:43 PM
RapidRobert
Assuming the throttle blades are closed down normally to where you are on the idle circuit if you then screw in the idle mixture screws all the way & it keeps idling then the PV is blown (the idle circuit is getting fed improperly from the PV)
