318 or 360?
#1462324
07/03/13 05:47 PM
07/03/13 05:47 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
Looking for a good small block to run in my 72 Scamp. I found a 1969 318 out of a Charger and a 1981 360 4bbl out of a motor home. Both run good and are about the same price. Which would I be better off with? I know the 318 is going to have better compression being a 60's model. But does anyone think the 360 is a better choice? Thanks
-ERIC
Re: 318 or 360?
[Re: Andrewh]
#1462326
07/03/13 07:07 PM
07/03/13 07:07 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
Yes I am dropping them in as is. I plan on getting the /6 to V8 conversion mounts from Schumacher and no I don't have a pan for the 360 yet. I guess what I'm trying to determine is which engine bone stock is going to give me the most power. Thanks for your help.
-ERIC
Re: 318 or 360?
[Re: Nimbus426]
#1462327
07/03/13 07:13 PM
07/03/13 07:13 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
For about the same price I don't see much of a question. 360 all the way. The slightly higher compression of the earlier 318 vs the torque of the 360's stroke and additional 42ci, is a no brainer to me.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: 318 or 360?
[Re: Andrewh]
#1462331
07/03/13 07:21 PM
07/03/13 07:21 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
The 360 comes with a working transmission and the motor is complete from top to bottom. Still has a/c compressor and power steering pump attached. It's actually a little cheaper than the 318 too. Torque is definitely what I'm looking for so I might just look into getting the 360. Any tips for some cheap horsepower?
-ERIC
Re: 318 or 360?
[Re: Nimbus426]
#1462332
07/03/13 07:34 PM
07/03/13 07:34 PM
Posts: 905 SD
zrxkawboy
SD
360, for the reasons mentioned above, plus, it will have hardened valve seats for unleaded gas.
It's Swifty! Swifty, you toad sucker!
Re: 318 or 360?
[Re: zrxkawboy]
#1462333
07/03/13 07:44 PM
07/03/13 07:44 PM
Michael Ecks
Columbus, GA
Excellent point on the hardened seats!
I don't know A bodies so well, but I am not sure a motor home 727 will bold right in, especially if it is like a normal truck loadflight vs car torqueflight. It would be trade or resell material though.
By the B&M 360 to 904 weighted flexplate and run a 904 behind it. The 904 uses less horsepower to operate so more ends up at the rear wheel. For stock pistons etc, a smaller cam like an edelbrock performer with matched valve springs will give you the best performance.
Re: 318 or 360?
[Re: Nimbus426]
#1462334
07/03/13 07:45 PM
07/03/13 07:45 PM
Posts: 15,487 Florida
scratchnfotraction
replace the low stall TC from the 360/MH trans to a stock high stall TC weighted for the 360 external balance.
thats the biggest improvement for bone stock 318 or 360 engine. IMHO.
then the regular bolt ons like carb/intake/headers/rear gears make a fun A-body
Re: 318 or 360?
[Re: Michael Ecks]
#1462336
07/03/13 07:53 PM
07/03/13 07:53 PM
scratchnfotraction
a short shaft 727 with bolt on yoke will bolt in and work if you build the drive shaft with spline/slip yoke. (I had a 76 short shaft 727 in my 68 Dart also my 88 440 truck with a BB short shaft)
Re: 318 or 360?
[Re: scratchnfotraction]
#1462337
07/03/13 09:34 PM
07/03/13 09:34 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
Sounds like the 360 is the way to go. I think it will give the most bang for the buck. Plus it is more complete and with a little work it will make a fun driver out of that Scamp. Thank you all for your input! You've been very helpful!
-ERIC
Re: 318 or 360?
[Re: Nimbus426]
#1462339
07/04/13 06:17 AM
07/04/13 06:17 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Use the 904.
As for the engine choice, as much as i'm on a small-engine big-efficiency kick, for what MOST people want, the 360 is the obvious choice. A Charger is just too heavy for a 318 anyways.
Better choice would be to continue shopping around and find a 5.9L 360 Magnum, and do that swap instead. Better mileage, way more power, hell... many different little bonuses overall. I just bumped a pretty informative thread about it.
Re: 318 or 360?
[Re: Pale_Roader]
#1462340
07/04/13 01:18 PM
07/04/13 01:18 PM
Posts: 16,122 Grand Haven, MI
patrick
Grand Haven, MI
if you want more power, go 360...if you want mileage, go with the 318....
for the 360, replace the cam with a lunati voodoo 60401 and valve springs with the comp #901's
if you want "free hp" run a 904 based 998 tranny--it has the lower gear set (2.74 first and 1.54 second, instead of 2.45/1.45) and it takes about 1/2 to 1/3 the power to spin than a 727.
