440 Kickdown Linkage Length #1462100
07/03/13 04:23 AM
07/03/13 04:23 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
Does anyone know what length the arms are, specifically from the carb to the upper belcrank and the vertical rod from the upper to the transmission belcrank. Trying to pick through a pile of linkage and need to determine the 440 from my smallblock stuff. Knew I should have marked all that stuff when I pulled it off the vehicles. Thanks.
Re: 440 Kickdown Linkage Length [Re: elmor353] #1462101
07/04/13 03:25 AM
07/04/13 03:25 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
Help. Anybody?
Re: 440 Kickdown Linkage Length [Re: elmor353] #1462102
07/04/13 09:38 AM
07/04/13 09:38 AM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
The 3 piece setup I removed from my 440 has a 8-1/2" upper rod from center of bell crank hole to end of threads. The intermediate piece is 14-1/2" from center to end of upper thread. I don't know if they are original parts but they worked find with plenty of adjustment.
