70 Challenger Door lock mechanism #1461980
07/02/13 09:16 PM
07/02/13 09:16 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
can someone please post some clear pictures of where the rods install for the door lock mechanism?
Got the car back from restoration and of course I can't lock my driver's door. Noticed one rod wasn't connected properly as they probably broke the retaining clip. Strange that it won't lock from the inside either.
I looked at the service manual but it's not very clear. Any assistance would be appreciated.
B5 Challenger T/A
Re: 70 Challenger Door lock mechanism [Re: KARLN] #1461981
07/02/13 11:43 PM
07/02/13 11:43 PM
What about taking the panel off of the pass side door & duplicating what's on that (functioning) side. It'd likely just be a mirror image, piece of cake
Re: 70 Challenger Door lock mechanism [Re: RapidRobert] #1461982
07/03/13 01:39 AM
07/03/13 01:39 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
They do wear out. I had to replace the drivers side mech in mine. See if you can use your hand on the lever and lock/unlock it with the rods disconnected.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 70 Challenger Door lock mechanism [Re: Silver70] #1461983
07/03/13 11:14 AM
07/03/13 11:14 AM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
tried to lock and unlock using the chrome knob inside and it doesn't seem to move the mechanism to the lock position. I can see that the rods are connected but can't seem to move the cam to the full lock position.
I guess I'll have to pull the passenger side and see but would still appreciate it if someone can post some clear pics.
B5 Challenger T/A
Re: 70 Challenger Door lock mechanism [Re: Silver70] #1461984
07/03/13 11:15 AM
07/03/13 11:15 AM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
I'm sure they wear out but both locks were working perfectly before the car went in for restoration.
B5 Challenger T/A
Re: 70 Challenger Door lock mechanism [Re: KARLN] #1461985
07/03/13 11:35 AM
07/03/13 11:35 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Does it lock and unlock with the key
Re: 70 Challenger Door lock mechanism [Re: AARCONV] #1461986
07/03/13 06:26 PM
07/03/13 06:26 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
no it doesn't. Took the inside panel off and noticed that one of the rods had come off. Looks like the retaining clip is broken. Re-installed the rod where I think it belongs but it doesn't lock. The machanism stays in the unlock position.
Any ideas why?
B5 Challenger T/A
Re: 70 Challenger Door lock mechanism [Re: KARLN] #1461987
07/03/13 09:43 PM
07/03/13 09:43 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
1 of 5
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: 70 Challenger Door lock mechanism [Re: cudaized] #1461988
07/03/13 09:44 PM
07/03/13 09:44 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
2
Re: 70 Challenger Door lock mechanism [Re: cudaized] #1461989
07/03/13 09:44 PM
07/03/13 09:44 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
3
Re: 70 Challenger Door lock mechanism [Re: cudaized] #1461990
07/03/13 09:44 PM
07/03/13 09:44 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Re: 70 Challenger Door lock mechanism [Re: cudaized] #1461991
07/03/13 09:45 PM
07/03/13 09:45 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Re: 70 Challenger Door lock mechanism [Re: cudaized] #1461992
07/03/13 09:49 PM
07/03/13 09:49 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
The 70 door latch/locking mechanism is unique. It doesn't allow one to lock the door until the door is closed and latched, or the latch is closed (simulating the closed door).
later year E-Body mechanisms are different. Allowing you to lock the door prior to closing it.
Ola
Re: 70 Challenger Door lock mechanism [Re: KARLN] #1461993
07/03/13 09:56 PM
07/03/13 09:56 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Any ideas why?
You may need to clean the mechanism thoroughly. Perhaps remove it. clean it, lubricate it, then reinstall.
It might be that simple.
Reach in and see if you can move the big round counter weight up and down (after the latch is closed).
It might be that the lock rod is not attached correctly?
I hope the pictures help.
Ola
Re: 70 Challenger Door lock mechanism [Re: cudaized] #1461994
07/03/13 10:56 PM
07/03/13 10:56 PM
BDW Offline
BDW  Offline
The only being able to lock it with a key is a pain.
I modified my driver's side so it locks when the door is closed like the later models.
Re: 70 Challenger Door lock mechanism [Re: KARLN] #1461995
07/03/13 11:59 PM
07/03/13 11:59 PM
Arkansas
N
Nimbus426 Offline
Nimbus426  Offline
N
Arkansas
I have the opposite problem. I can't get my door unlocked. Or unlatched is the better word. I haven't been able to open my 70 barracuda driver's door since I brought it home in March. I thought it was stuck in the lock position so I reached in and flipped the switch and it locked it instead. So the door is not locked and when comparing the working passenger door to this one the rods are pulling the same and everything seems to be working fine but it stays latched. And I have no earthly idea how to unlatch it with the door closed. Very frustrating especially when I stop for gas.
-ERIC
Re: 70 Challenger Door lock mechanism [Re: cudaized] #1461996
07/04/13 10:27 AM
07/04/13 10:27 AM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
the pics were very helpful!
Hope to get this fixed tonight.
Thanks everyone for your help.
B5 Challenger T/A
Re: 70 Challenger Door lock mechanism [Re: KARLN] #1461997
07/04/13 11:13 PM
07/04/13 11:13 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
quick update, the experts are right again the door locks from the inside with the door closed only. I reinstalled the rod that had come off but it still doesn't lock from the outside. It does turn the cam but not quiet enough to lock the door.
Any suggestions??
B5 Challenger T/A
Re: 70 Challenger Door lock mechanism [Re: KARLN] #1461998
07/04/13 11:44 PM
07/04/13 11:44 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Is the small lock rod bent?
Small plastic insert, where the lock rod is inserted, missing or broken?
Does it lock if you move the locking part with your hand?
Easy to try. Remove the small lock rod from the outside door handle and lock with your hand.
Re: 70 Challenger Door lock mechanism [Re: cudaized] #1461999
07/05/13 12:16 AM
07/05/13 12:16 AM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
the plastic insert was missing, I replaced it with a similar piece I picked up at a jobber. The rod doesn't appear to be bent but not really sure what the original shape was. I found it sitting on the bottom of the door as the plastic retainer was missing.
B5 Challenger T/A
Re: 70 Challenger Door lock mechanism [Re: cudaized] #1462000
07/05/13 11:52 AM
07/05/13 11:52 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Good stuff cudaized!
Re: 70 Challenger Door lock mechanism [Re: KARLN] #1819987
05/06/15 08:25 AM
05/06/15 08:25 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
An oldie, but a goodie.
