Thought it was a fuel issue #1461808
07/02/13 01:27 PM
07/02/13 01:27 PM
Loves Park, IL
HotRodRailroader Offline OP
Loves Park, IL
One day right after purchasing fuel, I noticed the car has a mini surge to it and a slight ever so slight miss to it at a higher rpm usually over 4000. Idles and starts perfect! runs great up to that rpm range. got the fuel out of there and changed plugs. power is back but still missing ever so slightly. Any ideas? timing is still where it always has been. Thanks!
Re: Thought it was a fuel issue [Re: HotRodRailroader] #1461809
07/03/13 03:56 PM
07/03/13 03:56 PM
Loves Park, IL
Loves Park, IL
Any ideas???????
Re: Thought it was a fuel issue [Re: HotRodRailroader] #1461810
07/03/13 04:13 PM
07/03/13 04:13 PM
Might block the metering rods up & try it out on the power circuit & see what it does. Easy to do & change back & no cost. Might see if rotor phasing is borderline (unhook/cap vac adv & see if it gets better/worse or no change)
Re: Thought it was a fuel issue [Re: RapidRobert] #1461811
07/03/13 05:06 PM
07/03/13 05:06 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I had very similar issue. Capping the Vac Advance (as Robert suggested for you) stopped the problem. I know you haven't changed the timing, but maybe if you have Ethanol in your fuel now it has created a change?
Facts are stubborn things.
Re: Thought it was a fuel issue [Re: larrymopar360] #1461812
07/04/13 12:01 AM
07/04/13 12:01 AM
Loves Park, IL
Loves Park, IL
I will try this first thing tomorrow as I am waiting to bring a train back to WI. I will post results! Thanks
Re: Thought it was a fuel issue [Re: HotRodRailroader] #1461813
07/04/13 09:52 AM
07/04/13 09:52 AM
jersey
Spaceman Spiff Offline
jersey
What engine? Carb? FI?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
