Re: Thought it was a fuel issue
[Re: HotRodRailroader]
#1461810
07/03/13 04:13 PM
07/03/13 04:13 PM
RapidRobert
Might block the metering rods up & try it out on the power circuit & see what it does. Easy to do & change back & no cost. Might see if rotor phasing is borderline (unhook/cap vac adv & see if it gets better/worse or no change)
[Re: RapidRobert]
#1461811
07/03/13 05:06 PM
07/03/13 05:06 PM
Posts: 15,827 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I had very similar issue. Capping the Vac Advance (as Robert suggested for you) stopped the problem. I know you haven't changed the timing, but maybe if you have Ethanol in your fuel now it has created a change?
Facts are stubborn things.
