which plugs for a 440 with MSD
#1449382
06/08/13 04:45 PM
06/08/13 04:45 PM
Posts: 231 Ct
gts1
Ct
Whats the best plug & what gap for a slightly warmed over 440 in a 69 B body auto with an MSD 6A always ran Autolite 86 is there something better.
Re: which plugs for a 440 with MSD
[Re: gts1]
#1449384
06/08/13 06:32 PM
06/08/13 06:32 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
Almost anything would be better since autolite moved the production of the standard plugs to Asia. If you want to stick with autolites buy the AR race plugs , at least mexico is within the shores
[Re: Dodgem]
#1449386
06/08/13 07:27 PM
06/08/13 07:27 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
I run copper Champions on aluminum headed small block gapped to 55. I'm pretty sure MSD recommends 55 too.
[Re: gts1]
#1449387
06/08/13 08:31 PM
06/08/13 08:31 PM
RapidRobert
OT, Might vary the plug gap (lower/higher) & NAPA sells an Echlin rotor with a .060" longer blade #MO3000 for $8 & change out the door & might check rotor phasing
[Re: Dougsmopars]
#1449389
06/10/13 11:34 AM
06/10/13 11:34 AM
Posts: 5,890 Athens, Greece
Pyper70
Athens, Greece
I run NGKs in mine but I am also running the RB, MSD 6AL, & Edelbrock Heads. Before the head swap I was running the factory Champion plugs. I still have like 16 in a styrofoam package from the 70s
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
