88 d-100 trans mount change? #1448602
06/06/13 09:35 PM
06/06/13 09:35 PM
scratchnfotraction Offline OP
trying to figure out what yrs the trans mount changed from the spool mount.
I have found a few pics trying to piece it together.
does the d-100 crossmember with new style mount swap or look close to the DAK crossmeber.
what all does it take to use this mount to bolt it to the trans and crossmember?
Re: 88 d-100 trans mount change? [Re: scratchnfotraction] #1448603
06/06/13 09:39 PM
06/06/13 09:39 PM
does this dak crossmember look right?
maybe it will work in a d100?
Re: 88 d-100 trans mount change? [Re: scratchnfotraction] #1448604
06/06/13 09:40 PM
06/06/13 09:40 PM
Re: 88 d-100 trans mount change? [Re: scratchnfotraction] #1448605
06/06/13 09:57 PM
06/06/13 09:57 PM
i think the piece on this granny tranny is needed also
anyone have these 3 pieces?
Re: 88 d-100 trans mount change? [Re: scratchnfotraction] #1448606
06/06/13 10:31 PM
06/06/13 10:31 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
Mike that doesn't look like the one I pulled from my V6 5 speed. Mine was roughly like the 904 crossmember. It bolted with two bolts each, on the top and the bottom of the frame on the drivers side, two bolts on the top on the passenger side, one bolt on the bottom of the passenger side, and where the trans mount goes the mnember is U shaped. mine was rotted or I would have saved it.
1981 Dodge D150 360 auto
Re: 88 d-100 trans mount change? [Re: scratchnfotraction] #1448607
06/06/13 10:31 PM
06/06/13 10:31 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
If it will fit the D frame, what will it do to the driveline angle ??
I am truckless..
