BB accessory brackets #1448526
06/06/13 05:31 PM
06/06/13 05:31 PM
Canada
CTD5.9 Offline OP
CTD5.9  Offline OP
Canada
I'm putting a 400 into my mud truck, the engine came out of my dad's collection and every time I look at the pulleys and belts all I can think of is there has to be a better way. Currently looks like this.
Does anyone know what they should look like? or if an aftermarket system like 440 sources "serpentine" pulleys would work instead?
Re: BB accessory brackets [Re: CTD5.9] #1448527
06/06/13 07:54 PM
06/06/13 07:54 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
What's the lower idler for? If you can illiminate that it looks fine to me.
Re: BB accessory brackets [Re: redraptor] #1448528
06/06/13 08:56 PM
06/06/13 08:56 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Eliminate. Hah. Everyone eliminated it. its easily bi-passed. They don't sell/make the idlers anymore.
Re: BB accessory brackets [Re: CTD5.9] #1448529
06/06/13 08:58 PM
06/06/13 08:58 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
lose the p/s and the idlers. simple.
Re: BB accessory brackets [Re: Golden-Arm] #1448530
06/06/13 09:02 PM
06/06/13 09:02 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Don't need that in a mud truck
Re: BB accessory brackets [Re: 76dodgeboy] #1448531
06/07/13 11:11 AM
06/07/13 11:11 AM
Canada
CTD5.9 Offline OP
CTD5.9  Offline OP
Canada
My tsl boggers already go wherever they want, I need as much help as I can in the steering department.
Thanks for the advice everyone, I am going to get rid of that lower idler and see how the belts line up with the 100amp alternator to see if that one can go as well. although I still might try replacing them with something like this
Re: BB accessory brackets [Re: CTD5.9] #1448532
06/07/13 12:06 PM
06/07/13 12:06 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
wow, someone has some deep pockets!!
really, an electric waterpump, no p/s and all you need is one belt to the alternator, but scratchin' will tell you, why you don't even need that for a mudder.
Re: BB accessory brackets [Re: CTD5.9] #1448533
06/07/13 07:36 PM
06/07/13 07:36 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
That's the setup I went with. Nice stuff.
Re: BB accessory brackets [Re: CTD5.9] #1448534
06/07/13 08:23 PM
06/07/13 08:23 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
My boggers work well too. My small block is set up like that with a 100 amp. Even my 440 2wd tow truck had a high mounted power steering pump without that wierd idler.
