cause for thrust bearing failure? 440 #1447331
06/04/13 07:55 AM
06/04/13 07:55 AM
ontario canada kingston
aspenrt360 Offline OP
so we are getting the crank fixed right now the thrust bearing failed big time! i have never even heard this engine run but it seems to have been put together ok. i am having the block tanked to get all the oil passages cleaned out then new bearings throughout. we will give it a hone and a fresh set of rings while we are at it. it only had 4000 miles when it lost the thrust bearing. the converter looks fine but i am worried about the trans i don't know much about it and i am concerned it may have had something to do with the bearing issue.what could be some of the possible causes and what can i look for? thanks guy's
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: cause for thrust bearing failure? 440 [Re: aspenrt360] #1447332
06/04/13 07:59 AM
06/04/13 07:59 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Last time I saw one go that quick, it was a spacing problem between the convertor and the back of the crank. Turns out the convertor had extra thick flex plate pads on it for a mid plate set-up...Owner assembled it not thinking the difficulty he had was an issue.
Re: cause for thrust bearing failure? 440 [Re: Dragula] #1447333
06/04/13 08:03 AM
06/04/13 08:03 AM
hmm the converter does have fairly thick pads on it i have not really looked at it to hard yet as i have been tearing down the engine and getting it to my machinist to have it speced out. so if the pads are to thick it does what? pushes the converter forward?
Re: cause for thrust bearing failure? 440 [Re: aspenrt360] #1447334
06/04/13 08:12 AM
06/04/13 08:12 AM
Dragula Offline
Dragula  Offline
Not saying that is your cause, but if the pads are too thick, it pushes on eveything. It will push the back of the crank and you will loose one side of the thrust...Take a look and see what it looks like. Post a pic if you can.
Re: cause for thrust bearing failure? 440 [Re: aspenrt360] #1447335
06/04/13 10:17 AM
06/04/13 10:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have good torque and the conv doesnt have balloning
plates the conv will grow and push on the pump and forward
on the crank... weak leak is the thrust bearing.. as
said if it didnt have some play to the flex plate it
will eat the bearing
Re: cause for thrust bearing failure? 440 [Re: MR_P_BODY] #1447336
06/04/13 01:58 PM
06/04/13 01:58 PM
i am going to pull it tonight and try to find some part #'s or somthing to id it. he say's it is a B+M. that does not mean much if i don't know more about it!
Re: cause for thrust bearing failure? 440 [Re: aspenrt360] #1447337
06/04/13 02:09 PM
06/04/13 02:09 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I killed my trust and could not determine why. Converter was fine, etc. My transmission guy who races sprint cars said he used to see alot of this and he puts in a oil grove on the trust side for additional oiling and it solved his problems. I did the same and have not had a problem since.
Re: cause for thrust bearing failure? 440 [Re: aspenrt360] #1447338
06/04/13 02:32 PM
06/04/13 02:32 PM
One way to check the preloading of the thrust bearing by the converter is to see if there is any play between the converter mounting lugs and the flexplate Mine usually have between .250 and .125 on torqueflytes. When you use a mid plate that removes the clearances nessitating redoing the converter to get some freeplay between the lugs and the flexpalte Take all four bolts loose and see if your converter will slide back and forth on the input shaft If it does and you have over 1/8 inch movement your probally good BTW, I have seen some that you need to put spacers(round washers) between the mounting lugs and the flexplate so you don't bend the fllexplate by tightening the bolts up when the mounting lugs don't mate (touch) evenly with the backside of the flexpaltes, in that case the converter hub was to long to allow the converter lugs to touch the flexplate like they should There is always a reason(and a cure) for component failure, figuring out the cause can be the hard part
Re: cause for thrust bearing failure? 440 [Re: aspenrt360] #1447339
06/04/13 02:48 PM
06/04/13 02:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In some rare cases the reaction shaft spins in the pump support and sends full line pressure to the converter instaed of a lower regulated pressure. This keeps a constant forward pressure of several hundred pounds on the crank.
Re: cause for thrust bearing failure? 440 [Re: John_Kunkel] #1447340
06/04/13 04:06 PM
06/04/13 04:06 PM
yep lot's of test fitting in my future! this guy is a good buddy and i would like to solve this problem for him. i hope i can figure it out. thanks for all the help guy's.
Re: cause for thrust bearing failure? 440 [Re: aspenrt360] #1447341
06/04/13 11:16 PM
06/04/13 11:16 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
we bent a flex plate and took out the thrust.
i also seen a block that had the mains line honed
and the caps were not cut on a 90. loosen the cap
and good end play. torque it down and it gets tight.
that may be something to look at on the failure if
nothing else shown up.
Re: cause for thrust bearing failure? 440 [Re: dmking] #1447342
06/05/13 09:24 AM
06/05/13 09:24 AM
an8sec70cuda Offline
I've seen an externally balanced 440 w/ an internally balanced flexplate eat up thrust bearings. Changed the plate and no more problems.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: cause for thrust bearing failure? 440 [Re: aspenrt360] #1447343
06/07/13 01:53 PM
06/07/13 01:53 PM
Out of the State of Confusion
blue_stocker Offline
I had one 440 that had a constant thrust-destroying problem in my stocker when I was running it in a stick-shift class. I never did find what was causing that dilemma?!
Re: cause for thrust bearing failure? 440 [Re: dmking] #1447344
06/07/13 01:57 PM
06/07/13 01:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I had a similar problem after a linebore only it locked the crank solid when the #3 was torqued down.
Re: cause for thrust bearing failure? 440 [Re: JohnRR] #1447345
06/07/13 02:07 PM
06/07/13 02:07 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I think a lot of these issues are caused by engine builders not SETTING ( or seating ) the thrust bearing properly during an engine build and correcting if needed the thrust bearing clearances. With more and more engines going together with NEW after market cranks and bearings made who knows where this area needs SPECIAL attention.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: cause for thrust bearing failure? 440 [Re: blue_stocker] #1447346
06/07/13 02:20 PM
06/07/13 02:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Could it have been the constant pushing of the clutch pedal ?
I'm adding a oil channel in the #3 bearing on my latest builds , going in stick cars, to help put more oil between the crank and the bearing.
Re: cause for thrust bearing failure? 440 [Re: aspenrt360] #1447347
06/07/13 03:02 PM
06/07/13 03:02 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Typical candidates are:
Rough on the thrust face of the crank. When the crank is machined it leaves "star burst" lines radiating outward. Very difficult to polish
Ballooning torque converter from excessive pressure in the converter
Lack of play between flex plate and converter
Excessive clutch pressure (4 speeds). The heavier the clutch, the more pressure needs to be exerted to release it. This force pushes the crank forward against the rear thrust surface. I try not to start my car with my foot on the clutch because there is 0 oil pressure. I also try to shift to neutral and have my foot off the clutch at stop lights.
Re: cause for thrust bearing failure? 440 [Re: pittsburghracer] #1447348
06/10/13 02:22 AM
06/10/13 02:22 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
99 and 1/2 percent of thrust bearing failures are related to the convertor,trans,trans cooler ,flexplate etc.NOT THE ENGINE BUILDER,HAVE YOU EVER SEEN A THRUST WEAR OUT ON THE FRONT SIDE?43 years in the engine building business never seen one thrust failure on the front side!Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: cause for thrust bearing failure? 440 [Re: BIGSPEED] #1447349
06/10/13 10:18 AM
06/10/13 10:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think he was talking about the PROFESSIONAL engine builder
Re: cause for thrust bearing failure? 440 [Re: pittsburghracer] #1447350
06/10/13 11:11 AM
06/10/13 11:11 AM
Delray beach, Florida
P
Performance Only Offline
P
I have to agree with this. generally speaking, It's not the experienced guys having these issues unless it's due to factors outside of the engine, but from what we see here, that's seldom the case.
Main caps cut crooked during a line hone/bore is a very common cause as is not setting the clearance properly during assembly and verifying it, especially when changing over to studded mains.
machine shop owner and engine builder
