Flywheel & clutch??? #1447067
06/03/13 08:34 PM
06/03/13 08:34 PM
Marysville, WA
77ProStreet Offline OP
Marysville, WA
Do I need "shouldered" bolts to attach the pressure plate assy. to the flywheel or can I use grade 8 bolts with just threads? My clutch and pressure plate are Centerforce dual friction.
Re: Flywheel & clutch??? [Re: 77ProStreet] #1447068
06/03/13 11:50 PM
06/03/13 11:50 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I like useing header bolts. That way it can be torqued well but not overly so..
I am truckless..
Re: Flywheel & clutch??? [Re: 77ProStreet] #1447069
06/04/13 06:26 PM
06/04/13 06:26 PM
Lehigh Acres, Florida
rickstershemi Offline
JMO....but I would buy the correct ARP Bolts for your application.....less than $20 and fagetaboutit
Rickster
